Results 1 to 7 of 7
Thread: vst phase plugin
    Jan 2009
    vst phase plugin
    i am searching a vst phase plugin.
    do you guys have nice one?
    Jan 2009
    sometihing else han phase bug and voxhengo...because they dont work
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by summer69guy View Post
    What do you think with it do not work? When Im once test it it has normaly work(change phase)...
    Jan 2009
    it had some weird sound
    Oct 2004
    Israel
    What's exactly wierd with the sound?
    I haven't had the chance to use the pha-979 one ( installed but wasn't tested yet )
    But with the bug filter i had some issues when only trying to apply it to one set of drivers , It created a wierd delay even at 0 degrees phase shift
    I think the solution is to apply the plugin to all channels and then play with the phase shift
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    Jan 2009
    thank you will try it.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    phase bug has a built in latency delay as a buffer for phase shifting. Somewhere around 9000 so if you use it it has to be used on all channels or use voxengo latency delay on the other channels to compensate/match. The delay is calculated via sampling rate (i.e. 44.1Khz/48Khz/96Khz...) and the latency delay number of samples.
    I think the voxengo phase plugin has a latency delay too but I don't remember. Console lists the latency delay in the plugins list in one of the columns.
  1. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  2. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  3. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
