Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Audio with carputer is not comparable to decent head unit...
  1. #11
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    There are three types of lies: lies, d@mn lies, and claims of superior audio quality.
    -Mark Twain
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  2. #12
    Mar 2009
    Have your amps got gain controls?.if so wind them down.
    are you using compressed audio files wma,mp3 etc as low sample rates will cause a loss of quality
    are your speakers up to the job?.can they cope with the amp output?.over drive them and muffled distortion is going to happen
    I'm using motherboard sound chip with 4ch amp with 12 speakers and a seperate 12" sub with own amp and it sound great.sound control is done through centrafuse and is totally controllable
  3. #13
    Sep 2009
    Two amps and both are Memphis. One is a 4 channel 75w and the other is 1 channel 1100w into the sub. The amps are literally turned all the way down.
    When turning up the volume on the carputer 25-30% its about as loud as you would expect at 90-95%. Accidentally clicking the volume slider up while hitting the volume up button results in an audio explosion that sends jolts through your intestines and makes you excrement on yourself.
  4. #14
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Either you turned your gain knobs on your amp turned the wrong way and they are maxed out or you have some gain in the software player maybe the EQ gain in winamp? Try another software player to check. I suspect your amp gains first as stated previously though, even if you THINK you have it set correctly check it again anyway. Third maybe see if anyone is reporting problems with the drivers. Sometimes you might have to go to realtek to get better drivers instead of what is supplied with the mobo.
  5. #15
    Sep 2009
    Ive got all the newest drivers. Im going to be reinstalling the system here soon... gonna play around with some stuff.
  6. #16
    Feb 2009
    Toronto Canada
    Im currently using the intel the blkdg45fc motherboard on windows xp and a programm called idt audio.This setup allows for 5.1.Im not using a centre channel but with the audio programm gives me the ability to adjust each individual speaker level and time alignment with i think 10 band eq. Sound quality was a massive imporvement being able to choose each speakers hpf or lpf settings.The only problem I encountered was the preout voltage that was below 2v.I solved this buy using 3 simple rca line drivers to my amps and then was able to turn the amp gains down and fine tune the speakers.This solved all my issues.Centrafuse control the graduall volume with no sound spikes..engines noise etc.Its sound quality by far surpasses what my alpine 505 produced before switching to my car pc and for less money.Hope that helps.
  7. #17
    Dec 2008
    also, everyone who has onboard audio needs to select the bitrate setting in the audio config. by default, its set to 16bit 44khz or worse, and i think thats why a lot of people get bad impressions. the newest onboard solutions can crank up to 24bit, 192khz and once you do that a whole other world of sound comes out.
  8. #18
    Aug 2006
    Portland, OR
    Quote Originally Posted by trader007 View Post
    ooo yes, one reason i love the xonar's. i've had a carpc for a bit over a year, everyone who's seen and heard the audio is wowed. i'm considering getting a line driver for it here soon though.
  9. #19
    Low Bitrate jake789's Avatar
    Apr 2009
    Best to use an oscilloscope to measure the output and distortion from your carpc.
    I have a pioneer deck along with a carpc. Using a 1khz test tone and the volume at max the pioneer was around 7v max. When using the same test tone on the pc (which runs through the pioneer aux) I saw a 9v max. So even though I didn't see any distortion I turned down my volume slightly on the pc so both sources would play at the same levels.
    I think this would help you see what type of distortion etc that is giving you so many problems.
  10. #20
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    i cant remember what the ratings are of my subs... but i do know they have never needed to be turned over 60% and when i leave them on 60% it allows me to have a nice volume range straight from the pc. This way they are not being over driven and this has been the case with a few installs that i have tested people's equipment on.
    With virtually all types of setup, You should be able to balance a nice range of the volume control on your pc to give you 1% barely audio if your ear is at the speaker to 100% with it at the limits of your speakers.
    Also in your case perhaps your might want to balance your pc audio out by lowering your WAV slider.
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
  1. Trying to hook up audio to Ford head unit.
    By Glyn in forum General Hardware Discussion
    Last Post: 09-03-2008, 07:40 AM
  2. Replies: 0
    Last Post: 01-06-2003, 02:35 AM
  3. Slot load dvd in a head unit
    By mp3truckstereo in forum General Hardware Discussion
    Last Post: 09-01-2002, 11:17 PM
  4. head unit w/ audio inputs
    By tbone in forum General Hardware Discussion
    Last Post: 08-06-2001, 03:53 PM
  5. Anyone using an FM tuner on their carputer instead of a head unit?
    By Szech in forum General Hardware Discussion
    Last Post: 02-14-2001, 03:07 PM
