Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: should I get a capacitor?
    Jan 2010
    Just recently I took my 95 ford taurus in for service. I asked em to check the battery and alternator. They told me the alt. was a little weak. It's probably because of the 2400watt(Idk if thats peak or rms) pyle amp powering two pyle subwoofers. Some people have told me that getting a capacitor would help prevent the alternator from being overworked. Most of them said that 1 Farad is sufficient. The reason why I'm hesitant is because of what some people say about capacitors. They say that they are not worth buying and should just get a high end battery. btw, my have a the battery replaced just recently because it how many times I left the lights on, so it's not a stock.
    Jun 2008
    Perth, Western Australia
    The capacitor is more to deliver the extra power needed when the amp and subs are working hard.
    It doesn't stop the alternator from having to work its backside off to supply the power needed for the system to run, but it can help stop some of the peak spikes that the amp can require.
    Think of the capacitor as a smoothing device, when the amp suddenly needs that extra shot of power for a split second, the capacitor is there to give that little extra. But it is only designed to help smooth those little spikes, not deliver a sustained supply of power.
    You can look at having the alternator upgraded to a larger unit if the current one isn't supplying enough power, however that does become a bit of an engineering challenge, as usually you would have to get someone to make up a new bracket to mount the larger alternator.
    Jun 2009
    No you should not, it introduces further strain on the alt.
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by hairyMerkin View Post
    Correct. The law of conservation of energy states that energy may neither be created nor destroyed. Thus you aren't going to be putting any less strain on the alternator, you're just moving it around at rates nicer to your subs when they need it.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    TODO:
    -Upgrade big three wires atleast: alternator positive to battery positive, battery negative to chassis, and engine ground to chassis
    -Get a better battery (exile or optima, or something like that)
    -get a more efficent amplifiers (class D), cheaper than replacing the alternator
    You should measure the current draw of your system, and check the alternators max amperage (130A I think).
    What kind of amps do you have?
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
    FLAC WuNgUn's Avatar
    Sep 2007
    You should get 3 or 4 caps! Would suit the Pyle hardware perfectly...
    Oct 2009
    Budapest, Hungary
    Quote Originally Posted by WuNgUn View Post
    Very evil
    Check my worklog:
    Sep 2007
    Sorry...couldn't resist.
    My only memories of Pyle is from an surplus-everything store, 20 years ago...
    Oct 2009
    Budapest, Hungary
    Well, to tell the truth, I didn't even heard of it until now, but their homepage is not too promising. And I think the 2400W RMS is on 18V, not on 12V
    Check my worklog:
    Sep 2007
    I think 2400 watts would only happen if you ran 110V to it, and then only for a split second...
    I think Pyle rates the amps at the first power up...that 'POP' sound you hear
  1. Installing a capacitor...
    By Urinemachine in forum General Hardware Discussion
    Last Post: 07-02-2009, 07:05 AM
  2. help wiring a capacitor to filter noise
    By kuo in forum LCD/Display
    Last Post: 06-08-2009, 01:07 PM
  3. Audio Capacitor Wiring Question
    By ajscomp372 in forum Car Audio
    Last Post: 03-22-2009, 12:27 AM
  4. Replies: 4
    Last Post: 07-30-2008, 07:54 PM
  5. Capacitor time formulas (for noobs)
    By KyleYankan in forum Newbie
    Last Post: 03-30-2005, 04:32 PM
