Results 1 to 3 of 3
Thread: Is this a grounding issue?
    Mar 2007
    Milwaukee, WI
    Hi all,
    I have kind of an interesting issue I'm hoping you can help with. My CarPC has some fairly loud static using onboard audio. It does not fluctuate with volume, so if I turn the music up enough I can't hear the static. I figure this is because my ground/power/audio are all basically pretty close to each other, but here's the interesting part: I unplug the audio from the motherboard and instead plug it into the zune (without moving the wires much) and the static drops to near nothing. So my thoughts are a grounding issue with the Mobo or interference from the power/ground wires affecting audio on the mobo.
    Currently using:
    Via epia m13000 (yeah, it's old)
    M2-ATX
    Power, ground, audio wired to the factory harness (line-level audio into harness goes to factory amp)
    Any ideas would be appreciated, as I have a few ideas but I'm not sure where to start.
    Brian
    2008 Grand Prix GXP
    [=====-------] 50% - Main Hardware Complete
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    I would first be looking at a grounding issue, How currently do you have your setup installed? Do you have a short common grounding loop?
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
    Mar 2007
    Milwaukee, WI
    Quote Originally Posted by mayhembdm666 View Post
    Here's the general setup at the moment (click for larger):
    I'll have to try grounding the M2 directly to the car (instead of the harness) with a shorter cable tomorrow night. I thought going through the harness would prevent this issue, but I guess I was wrong. The fact that the zune works perfectly leads me to suspect a power/gnd issue as the audio wiring must be good. At least I know that looking at grounding issues is a reasonable place to start.
    Brian
    2008 Grand Prix GXP
  1. Bluetooth GPS connection issue - 1.1.0.0
    By Sinabl in forum StreetDeck Bug Reports
    Last Post: 12-14-2007, 09:36 AM
  2. .M3U issue "Play all" issue
    By Kimota in forum StreetDeck
    Last Post: 12-12-2007, 09:34 AM
  3. Video Full Screen On/Off issue - 1.1.0.9
    By Kimota in forum StreetDeck Bug Reports
    Last Post: 12-12-2007, 09:06 AM
  4. Boot issue
    By Slippin3 in forum Power Supplies
    Last Post: 02-07-2006, 01:19 PM
  5. More of a PSU/Inverter issue
    By slasherx in forum Power Supplies
    Last Post: 08-11-2004, 06:14 PM
