Results 1 to 10 of 17
Thread: causes of lights dimming...
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    First, lemme describe my setup:
    m1-atx powered computer (so max 90W)
    ~300W-ish amp powering 2 12" subs
    xenarc in-dash MDT-X7000 ~55W x 4 (220W ?)
    Even with no signal going to the amp, I get random power drops and the lights dim. It happens randomly in several minute intervals.
    Looking at the specs for the xenarc, if it truely is 220W, I'm only powering it via the stock HU +12 connection which can't be very high gauge wire. Could that be the cause of my lights dimming?
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Mar 2006
    Colorado, but Canadian!
    If that monitor truly takes 220W @12v (18+ Amps), then there is something seriously screwy with Xenarc engineers...
    If you keep it in neutral or clutch depressed, whatever and then rev the engine and maintain it does the problem still happen?
    1.9in x 2.9in -- 47mm x 73mm
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by 2k1Toaster View Post
    That Xenarc unit has a motorized screen, built in DVD player and 55Wx4 amplifier. 220w and 18+ amps sounds about right.
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    I can try. It seems to happen if I'm idle (800rpms) or moving (2000). It'll be hard to test because it happens randomly. I'd have to rev my engine for a long time (5-10mins).
    The touchscreen's speaker amp is rated at 55W x4, so maybe add an amp to power the actual LCD...
    Mar 2006
    Quote Originally Posted by Machinehead View Post
    Aah. I didnt bother to check out the link I had in my mind just a regular screen molded in there. Well then, that could be a source of your problems, most cars are electrically limited to 15A or so on the stock wiring harness, but who knows.
    Quote Originally Posted by kev000 View Post
    Burn those fossil fuels!!!
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Oh, dispite the claims of 55W x 2, the specs also claim a power draw of 120W. Whatever that means...
    Forgive my ignorance, but if it tried to pull more than 15A, wouldn't the fuse pop? I remember having to replace the fuse a few times. It's either 15A or 20A...
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    That's marketing!
    But yes, if you pull more than a fuse is rated for, for more than the time it's rated for that current, it will pop. Also... as I've said (to you :P) before.... running off the factory wiring, even though the fuse is rated for it is never a good idea, they a lot of times under-size the wires because they know they'll never pull that much. It's not enough to cause a fire, but enough to cause a voltage drop across the wire. I'm not sure if that would cause headlight dimming... but it's certainly not good.
    RevFE
    My Shop
    Mar 2006
    More than likely it can put out 55W max on both channels (110W) and then the additional 10W is for heat and other various components to make it happen. Rather normal.
    And if you pull more than 15A on a 15A fuse, ideally it would blow. Not always though. There is generally a percentage range on the fuses where it just gets hot but doesnt blow.
    Jun 2007
    I wonder if the fuse has gone bad but hasn't popped, so the circuit is still drawing intermittently.
    Jan 2008
    how do your battery terminals look? if they have any corrosion, the car can do wierd things. also, do you have the vent selector knob on defrost? this can also cause it if the a/c pump is drawing a lot
    i really don't think that it has to do with the audio/computer system at all though-- audio stuff really only draws heavy when you have it turned up. but to prove it, you can pull the fuse(s) for all your carputer/amps, and the problem should still be there.
  1. Programmable lights.
    By Crinos in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-28-2011, 08:20 AM
  2. Lights dimming on bass beats :(
    By jellymonster in forum General MP3Car Discussion
    Last Post: 09-08-2009, 12:13 AM
  3. Lights dim when bass hits, weird.
    By Dillusion in forum Car Audio
    Last Post: 07-26-2007, 02:20 AM
  4. FS: EQ, Speakers, and Driving Lights
    By techy101 in forum Classified Archive
    Last Post: 06-25-2006, 04:33 PM
  5. VW Owners / Dimming lights
    By TheSpatulaOfLuv in forum Power Supplies
    Last Post: 09-16-2005, 08:48 AM
