Results 1 to 3 of 3
Thread: no sound to rear speakers / how to fade?
    Aug 2005
    so I have a new asus motherboard and I am using the onboard sound utilizing 6.1 with no center speaker hooked up.
    if I go thru the audio utility to "test" the sound I get a test tone from all speakers both front, rear and sub. I can adjust the levels via the audio utility etc... all seems great.
    but.... when I play music via winamp or windows media player all it plays is my front speakers. does not output anything to my rear speakers or sub.
    what is the trick to get these players to realize I have front / rear / sub and not just front speakers?
    thanks in advance!
    Heath
    First Carputer in progress.....
    Mar 2009
    Has the on board 6.1 not got a program utility that you can run to select amount of speakers in the menu?.Mine has
    Aug 2005
    It does, I found the issue. I needed to check the box that enables "speaker fill"
    So 1 problem down, many to go
    Heath
  1. Replies: 10
    Last Post: 06-27-2009, 02:21 AM
  2. Rear speakers too low to be correct..
    By briderx in forum Car Audio
    Last Post: 08-31-2007, 05:47 PM
  3. Excellent sound from speakers, very quiet sub
    By xraycat in forum Car Audio
    Last Post: 07-10-2007, 03:38 PM
  4. No Sound From Rear Speakers
    By rigg419 in forum Car Audio
    Last Post: 01-18-2007, 10:52 AM
  5. M-Audio Sonica Theatre, can't get sound from rear speakers
    By Lum in forum General Hardware Discussion
    Last Post: 01-21-2006, 08:27 PM
