Results 1 to 10 of 16
Thread: [FIXED] Amp wiring problem, sub cuts out and amp goes into protect mode HELP!
    Feb 2010
    Exclamation [FIXED] Amp wiring problem, sub cuts out and amp goes into protect mode HELP!
    I have a ford taurus 2005 with a p1800.4 (4 channel crunch amplifier) and a Hifonics 12" 12d4 subwoofer in a sealed box, when I first intsalled it, it was fine now it cuts out and amp goes into protect mode, my ground is fine ive tried wiring in bridged unbridged, parrallel series, u named it ive tried it.
    -power wire 8 gauge
    -ground 8 gauge
    1 12" Hifonics sub
    2 sony xplod 5x7 rear speakers (fronts arent hooked up)
    If somebody could please help me out, is there something simple im missing?????
    FLAC WuNgUn's Avatar
    Sep 2007
    Are you running the sub and the 5X7's off 2 channels? i.e. stereo drivers and bridged sub? If so, this is probably too much load for the amp...
    That, or you have a bad wiring connection at the speaker/amp...make sure you dont have any frayed wires shorting out.
    Feb 2010
    i have the sub bridged on one channel (1/2) and the spekaers in channels (3/4) unbridged obviously, connections are fine, I ran a volt meter and when the amp is on and playing its 12.35, its at very low volume of course because it still cuts out. that is normal isnt it, here is a text diagram of the wiring
    Terminal (1/2) (Subwoofer) (*-*)(+)(-)(*+*) <---bridged
    Terminal (3/4) (Speakers) (*-*)(*+*)(*-*)(*+*) <---- single channel mode
    4 channel amp
    any other help? i feel like ive tried all solutions.. I appreciate your responses
    Jan 2008
    what is the final load of the sub at the amp?
    what have you checked with a dmm?
    edit: missed the 2nd post...
    Feb 2010
    http://a248.e.akamai.net/pix.crutchf...4-ohm_mono.jpg
    Except its a 4 channel amp, ive tried wiring it different ways too
    Constant Bitrate thewizard's Avatar
    Dec 2008
    You can't run a four channel amp in the configuration that you are trying to run. You can the bridge the four channels to two but thats it, you cannot run it as a 3 channel. This is your problem.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Pioneer DEQ-9200 digital processor
    Phoenix gold line drivers
    Ultimate and Visonik amplifiers
    SMT 3 way active front stage
    Digital Design sub woofers
    3 runs of 0 gauge wire
    Jan 2008
    you have 2 options-- either wire the sub to only the left channel (i have used some small 35x 2 channel amps and subs setup in my brothers cars this way..) (most bass is on the left/mono channel), or get a different amp...
    Feb 2010
    thewizard, i dont mean to correct you but i had this setup the same in my room and it ran fine and stable, it just does not like my car, it even says and shows diagrams in the amp manual that I can bridge a sub and run the 2 speakers for the 3/4 channels. it is a bridgable amplifier,
    and soundman, ive tried it on just the left channel and it does the same thing cuts out into protect mode, ive even tried it with all terminals without any speakers connected, just the sub was same thing.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Easy answer...
    You didn't match the sub's impedance to the amp's bridged impedance. The amp can drive a minimum of 4 Ohms when bridged. That sub is either a 2 or an 8 and i'm guessing its a 2 if it went into protect.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Its best to keep discussion in the thread it started in, that way other forum members who have the same questions can benefit.
    Your PM:
    Quote Originally Posted by Chrizzzle
    hey so this is my sub it says its a dual 4 ohm
    http://www.sonicelectronix.com/item_...+HFi+12D4.html
    how do i match it up here is my amp also
    http://www.sonicelectronix.com/item_...h+P1800.4.html
    Dual voice coil means you have two 4 ohm loads but depending on how you wire them you either get 1 8ohm load or 1 2ohm load. Take a look here:
    http://www.crutchfield.com/S-Id7OCe6...fers_dual.html
    and if that doesn't clear things up let me know.
Tags for this Thread
