Results 1 to 9 of 9
Thread: Problem Amp Hifonics Zeus ZX 5.1
    Dec 2009
    Hi,
    I buy a Hifonics Zeus ZX 5.1... all ok if I use a Analog input!!!
    But, In monitor output hava a green screen with "Direct5" in left-up corner... but when i use the remote control, do nothing...
    How can I use the digital input?
    I have +12 in "RMT" an "ACC" inputs... is any of this is off... the amps never activate... the remote control not working!
    Can any help me??
    Thanks!
    Dec 2009
    Ir
    I think the probles is the IR EYE... I open this.. and i see a resistor and capaciter ... the IR only have "3211", "3F", and "1247" letters...
    IR have 3 connections... middle is 0v. or negative.... others have 1,47v and other have 2,5v
    i don't have more info... Can you help me please?
    Thanks!
    Apr 2010
    At me too a problem. The control panel is broken. I saw that it is possible to alter on TSOP1738. I have altered, but unknow what panel should approach.
    Mar 2011
    Hi,
    I have the same amplifier without the factory remote or ir receiver so i tried a few things to see whats going on. First I connected the wires (12v,gnd,rem,att). Next I connected the video out to my video input on my lcd and it displayed "direct 5" on the top left of screen. Hmmm...don't know what that means. I checked the voltage on the ir port by (splicing the wires of an old tape to 3.5mm adapter) using my multimeter on each wire. Red=5v, Black=ground, White=data. I have ir eye from another device that i tried to find codes using my Phillips Pronto tsu3000 but no luck yet.
    Apr 2010
    I have restored the native remote pult. But I will operate the amplifier by means of Arduino. I can send codes of commands of the remote in HEX a format. Later.
    Mar 2011
    Ok that will work!!! Which Arduino model are you using and where did you purchase? I am thinking about this one:http://www.geeetech.com/index.php?ma...roducts_id=252. Will I be able to use the slim remote that comes with the kit or will I have to use another advanced remote? I have the Phillips Pronto TSU 3000, but would love to use a different remote. Please send the hex code to my email. Thanks for replying to earlier post.
    Apr 2010
    Quote Originally Posted by darmain511 View Post
    I have already made such thing. Now I program. While Arduino break at attempt to transmit a signal. The computer of a command from the panel accepts and processes. But Arduino yet doesn't transfer. I understand.
    Mar 2011
    It looks like the amplifier is looking for pulses transmitted through the data input line from ir receiver. If you send me the hex codes for the remote I can help. I need this information from you since I do not have the remote. The Arduino is fully capable of solving this easy task. I may need to ask elsewhere for remote code.
    Apr 2010
    //Hifonics - DEC HEX
    //Hifonics - Power 4288612599 - FF9F08F7
    //Hifonics - Input 4288622799 - FF9F30CF
    //Hifonics - Mode 4288669719 - FF9FE817
    //Hifonics - VolUP 4288630959 - FF9F50AF
    //Hifonics - VolDWN 4288626879 - FF9F40BF
    //Hifonics - Test 4288639119 - FF9F708F
    //Hifonics - Source 4288632999 - FF9F58A7
    //Hifonics - Setup 4288628919 - FF9F48B7
    //Hifonics - Up 4288671759 - FF9FF00F
    //Hifonics - Down 4288647789 - FF9F926D
    //Hifonics - Left 4288614639 - FF9F10EF
    //Hifonics - Right 4288610559 - FF9F00FF
    //Hifonics - Enter 4288667679 - FF9FE01F
  1. Problem with SPL amp in protected mode
    By Memphistwelves in forum Car Audio
    Last Post: 06-08-2009, 07:22 PM
  2. Replies: 0
    Last Post: 08-28-2004, 03:14 PM
  3. Having problem with AMP, need HELP!!
    By ryuandwings in forum Car Audio
    Last Post: 05-01-2004, 07:31 PM
