Results 1 to 10 of 11
Thread: carpc to amp
    Jan 2010
    carpc to amp
    hi i just wanna know will this thing work fine with carpc setup directly to amp without head unit http://cgi.ebay.com.au/USB-2-0-Video...#ht_3547wt_939
    thnx in advance
    May 2007
    That device is for recording video to your computer, so no it wont work. You are looking for a usb soundcard.
    Jan 2010
    thanks
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    and even a sound card will need to be amplified...
    Mar 2008
    I'm wondering will i need amplification if i'm using spdif out to amp?
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    No...but make sure the amp has an spdif in (its rare and expensive)
    Jan 2010
    i have kenwood kac m645 amp http://au.kenwood.com/Car_Entertainm...fiers/KAC-M645 it worked with rca to 3.5 mm lead but the only thing which annoys me is popping noises.... i m using carnetrix 2140 to power dell optiplex sx270....
    Mar 2009
    Im using 3.5mm to rca with a kenwood amp similar to the OP and I have no popping issues with my carnetix 2140 psu to a mac mini. Do you hear the popping all the time or only during certain times?
    Jan 2010
    all the time.... what are the settings of gain on ur amp..??
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    poppping would'nt be the gain.. unless your hearing the pop sound on louder output. If its popping in low volume I would steer towards weak connection either in low input(s) RCA's or the output voltage is lower than amps min requirments. Remember that headphone outs (ipod, PC, in general usually have >0.4v max output. I would start @ looking at your amplifiers specs and see if it can handle very low input.. A perfect match would be min input range of 0.2--8V, if yours is 2v min as most.. then I would suggest a line driver or connecting an Ipod and see if the problem persists. This can help eliminate the PC end so you have a general idea of where to start the troubleshooting. if it srtill pops is amp or wires if it disapears then its the PC outs. Hope this helps.
    Did it.. Done it... now I got to keep the neighbors kids away!!
  1. Cant do a CarPC without an amp huh?
    By TexasAggie in forum General Hardware Discussion
    Last Post: 05-30-2009, 06:06 PM
  2. need amp turn on delay, speakers pop
    By customaudioman in forum Car Audio
    Last Post: 05-22-2009, 01:27 PM
  3. AMP Popping, Hissing, Shutting off...PLZ help?!
    By Dougw133 in forum Car Audio
    Last Post: 12-10-2007, 09:24 AM
  4. Powering carpc and amp
    By bjfrank in forum Car Audio
    Last Post: 04-11-2006, 02:32 AM
  5. Replies: 4
    Last Post: 05-17-2005, 05:17 AM
