Results 1 to 4 of 4
Thread: AMP Problems
    Feb 2010
    AMP Problems
    ok so i have a hifonics 1610d and it was working just fine for about two weeks. i moved the ground to have a better connection but now the amp wont put power out at either of the grounds. the hifonics still lights up but neither the power light nor the protect light is on. any suggestions or helpful info is greatly appreciated. thanks T
    Jan 2008
    have you checked everything with a voltmeter yet?
    Feb 2010
    yeah i checked everything without the amp its 14 volts with the amp it drops to 2. somethin. obvious problem indicator lol. what shold i do?
    Jan 2008
    14 with it running?
    usually it should be around 11-12 with the engine off.
    it could be a bad ground, a partial/blown fuse, or a loose connection anywhere in the car, or a bad switched line.
    are you just testing the constant power line, or have you tested both the constant power, and the switched power lines, both with the car on and off?
    also, is your ground good and solid, or just bolted up to the nearest point?
    the other thing i have learned to check is that none of the cables are pinched anywhere(i blew 2 amps and a headunit with pinched rca cables...
  1. Power missing to AMP
    By Pint in forum Newbie
    Last Post: 11-13-2007, 10:09 PM
  2. amp problems help
    By geramie in forum Car Audio
    Last Post: 11-03-2007, 01:43 AM
  3. Amp problems, help me plz
    By streikr in forum Car Audio
    Last Post: 10-27-2007, 12:23 PM
  4. Amp Problems
    By mwakeboard in forum Car Audio
    Last Post: 03-29-2007, 09:47 AM
  5. AMP problems....again
    By naevity in forum General Hardware Discussion
    Last Post: 02-17-2004, 10:06 AM
