Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: CARPC as Thumb Drive for Head Unit
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Question CARPC as Thumb Drive for Head Unit
    I picked up a cheap head unit that has an SD Card Reader, USB Thumb Drive Reader and an AUX Input.
    I want to be able to connect my CarPC to the USB Input and have the head unit read files from a specific directory.
    I only found one thread similar to this so far and have also googled this. All my finds turn up with Head Units with Ipod control. My head unit does not have Ipod control just simple USB Thumb drive reader.
    Essentially I want to be able to use my carpc as a thumb drive.
    Q: Why not just use a thumb drive?
    A: I want to use one pc to serve up the media files to devices that can use them. Smart Phones, Head Units, Network Connected Video Devices. This same PC will be used for Vehicle Montoring and other features as well. So I dont want a ton of programs playing music files or video files, just want devices to connect to the PC so that the files can be shared with multiple devices at one time.
    Q: Why not use bluetooth?
    A: Possibility but I dont want a blue tooth program running in the background, ie bluesoliel (they seem to be pretty resource heavy)
    Q: Why not setup a web server in the car?
    A: Part of the plan but still need to be able to use this with head units as well.
    how can i do this?
    New Age Garmin - Skin for RR
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    It is possible that you could use a PC to PC USB transfer cable to set up a "virtual thumb drive". I'd say that running this kind of software, if you could even get it to work, would be as CPU intensive as just running a music front end.
    You are never done installing a CarPC.
    Aug 2006
    West Allis, WI
    PC to PC transfer cable not really what I want. Need to connect PC to head unit so head unit can use MP3 files for playback.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Whats the point of the carPC then?! Just use an laptop drive....or an ipod....one wire and your done.
    The simple answer is no you can't use one host to access another-usb doesn't work that way.
    The long answer is that you could use a usb crossover cable, custom hardware to intercept the file I/O requests and redirect them to network access requests and then custom software on the PC to handle the I/O.....but do you really want to do all of that for a half-assed setup?
    Jun 2005
    chicago, Illinois
    I think I did read somewhere that the USB port on the headunit can control an ipod that you can hack the ipod cable with the help of specific hardware and software to do something like what you describe. But attempting this may use the same amount of processing power than just playing it from the pc as you are still transferring and translating the music files as data.
    PROGRESS:
    Aug 2006
    West Allis, WI
    Quote Originally Posted by justchat_1 View Post
    QUESTION: Whats the point of the carPC then?! Just use an laptop drive....or an ipod....one wire and your done.
    Quote Originally Posted by ME View Post
    ANSWER: So that I can use the carpc as a central storage device that can share files with many devices at once. I am wanting to have 2 head units. One in front and one in back. Maybe even a third. I also want to be able to share video files with connected devices. Wifi or network capabilities would solve this, but still want the ability to share mp3's with multiple devices that are not network capable, IE Head units.
    Technically the CarPC would be used as a Clone Thumb Drive
    Im sure this can be done, just wondering if anyone has done it yet.
    This is not an attempt at half arsing anything, just trying to find another capability
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by ThunderStick View Post
    I guess I didn't explain it well enough....heres try #2:
    USB is a tiered-star topology with a host at the top and lots of devices underneath it. A usb host is a piece of hardware not a software configuration that can be changed. Computers are equipped with USB host hardware, head units are equipped with usb host hardware, neither are capable of being a device. What your trying to do is like trying to plug two male sockets together-it just doesn't work.
    Your best bet would be to find a usb drive that allows multiple host connections. Some harddrives (NAS units) allow connection of more then one and some will allow a simultaneous usb and eSata connetion. For the most part though, stop trying to use a headunit as a carPC! THEY'RE NOT THE SAME!!!!!
    Aug 2009
    Virginia
    Are you even reading the posts? A USB PC to PC cable like what I described is the only, marginally possible way to acheive what you are trying to do. Just like justchat_1 has said twice now, what you are doing is possible MAYBE with a bunch of hacking, and custom hardware, AND custom software. Just to get the results that ONE carpc can already give you.
    Aug 2006
    West Allis, WI
    Quote Originally Posted by Spikemonkey View Post
    Wow simple question turned to the dark side allready, at least were keeping pace with the common mp3car.com forum culture. I guess the USB gospel is now set in stone, there is no way to share files via USB cables becuase one person answered with a NO.
    You maybe just a monkey so let me clear things up for you, I understood what justchat_1 was saying. Just prying and picking anyone else's brain that may read this. There are a lot of bright people on this forum and and I always seek a second and third opinion since one persons definite answer maybe proven otherwise by someone else.
    Like you said using a USB PC to PC cable allows file transfers between two computers, that would be two hosts connected via USB. So to clear up the illusion that you can't connect to host devices together may not be as factual as percieved. Yes using a standard cable you might not be able to do this, but with some provisions it may be possible.
    I dont believe in the word CAN'T, which is why I have allways asked questions on this forum. The belief is that you can if you try and trying never hurts (unless your trying to rob honey from a bee nest, that's a whole other story).
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I wonder if it is possible to make a usb host chip emulate a slave chip? probably not in windows if at all.
    RevFE
    My Shop
  1. USB head unit?
    By dgr in forum Car Audio
    Last Post: 10-19-2009, 01:51 AM
  2. Seat Ibiza Mk4 Alana Head Unit - need sound in!
    By onlineamiga in forum General Hardware Discussion
    Last Post: 02-11-2007, 05:02 AM
  3. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  4. CarPC radio reception: PC tuner or head unit?
    By xraycat in forum Car Audio
    Last Post: 01-18-2007, 06:57 PM
  5. Head Unit: Sony/Panasonic?
    By OdoyleRules in forum Car Audio
    Last Post: 02-25-2006, 06:03 AM
