Results 1 to 7 of 7
Thread: Front bass source?
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Front bass source?
    I have logic components up front (great highs but miss all low end) and 2x Kicker 6.5" sub up front (not installed yet). I like some mis/bass up front so I'm putting the Comp CVT's up front in the doors to.
    I was wondering what you guys would use as a channel source?
    the options:
    1. the front channel's (with low end crossover) to split right and left bass lines or
    2. the sub channel so as to get the same bass line from both the right and left stage as the highs are split.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by djvillar View Post
    the options:
    that all depends how far into the "mids" you want to go. the sub channel wont really give you much midrange if it has crossovers built in.
    Jan 2008
    just a couple of questions:
    what kind of crossovers are you using?
    what size speakers are they?
    how many outputs does your sound card have, and how many are you planning to use later on?(multiple subs, mids, midwoofers, tweeters?)
    Sep 2006
    New York, New York
    Quote Originally Posted by soundman98 View Post
    The amp's crossovers for the CVTs (if I use the right/left channel) or the Sub/Center channel (low end filter is active here)
    center stage:
    1x - 4" infinity kappa
    front stage:
    2x - 1.5" logic tweeter
    2x - 6.5" logic mid woofer
    2x - 6.5" kicker sub
    rear stage:
    2x - 6x9 infinity kappa (highs dampened quit a bit with filter)
    Sound Blaster X-Fi Xtreme Audio PCI Express:
    Line in / Microphone in (shared 1/8" mini jack)
    Speaker out (4x 1/8" mini jacks)
    Optical out (TOSLINK)*
    Optical in (TOSLINK)
    Intel HD Audio Compatible Front Panel Header (2x5pin)
    Jan 2008
    i like really loud, clear music, so my opinion would be to scrap the 6.5" subs for some thin mount 8's, or 10's, but anyways...
    if i remember right, your running Console right?
    if you are, then trying different crossovers would be that much easier-- try running the kickers as a active set, with something like a 150-200hz lowpass, and a 50-80hz highpass (i never had too much success with loud volumes, anything less then 50hz bass, and 6.5"s).
    Jul 2006
    LI, NY
    Yeah if you're looking for loud bass up front (anything you can feel) I would suggest at least using some 8" woofers and I wouldn't door mount 'em
    go for some underseat options.
    But a single 10" in the trunk should provide more than enough bass if U have space back there
    Sep 2006
    New York, New York
    I'm not trying to shake the door off the hinges, I'm just looking for some bass up front. Right now the highs in the front are overwhelming. They're not mounted in the factory location. I made a custom enclosure witch houses two 6.5" woofers with separated air spaces. The sub will receive .21 cubic feet (min. .2' cubic per man. spec) and i'll put some dampener in there as well.
    There's very little room under my seats but when it gets warmer I could look into it.
    The pods are already done though so if it sounds okay, I'm leaving it as is.
  1. RR wont start
    By lez in forum Road Runner
    Last Post: 09-30-2007, 05:30 AM
  2. Error GPS (MapPoint)
    By rob_69er in forum Road Runner
    Last Post: 04-28-2007, 12:06 PM
  3. Open source VB car front end?
    By jcohen in forum Coders Corner
    Last Post: 01-10-2006, 01:56 AM
  4. I cannot get the new version to show up ????
    By tolisn in forum RR Bug Tracker
    Last Post: 02-14-2005, 12:37 PM
  5. Update: 2-12-05.. Flash Support!...
    By guino in forum Road Runner
    Last Post: 02-13-2005, 01:21 PM
