Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: İs it possible to use semi-proffessional soundcards like crossovers?
  1. #11
    Jan 2008
    maybe just try a 8 input for now, and see how you like it.
    after playing with my setup, i scrapped my rear speakers altogether...
  2. #12
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by durwood View Post
    the audigy cards use different codecs on some of the channels and the resampler is not so good causing a bit of extra garbage in the upper frequencies.
    1010LT says you can use 2 cards together for 16 channels, but I haven't seen anyone do it. Do you need more than 8?
    LOL Really??
    I run two Xonars (16 channels) for my 2-way active output (front/rear/sub/VU Meters), and the onboard soundcard for my HD Radio inputs and Mic input. That's 3 sound cards....
    However, I've only found 1 set of Asus hardware drivers that allow all 16 channels to be used in Audiomulch/ASIO4All...a LOT of trial and error, but it works beautifully...
    I can't say whatever two soundcard you choose will work properly though.
    Here is what it looks like in Audiomulch (minus the VU Meter output...I simplified the chain to allow 24bit/96Khz sampling)
    Here is another 'contraption' showing EQ, seperate crossovers and time alignment...
