Results 1 to 2 of 2
Thread: 1000rms 2ohm amp mono block
    Mar 2010
    i have a 1000rms mono block one channel amp and i also have 2-12'' 4ohms dvc infinities i need to know how to wire them correctly.
    Jan 2008
    first, a little quote so you realise what you are getting into here:
    Quote Originally Posted by the stickey that no one pays attention to
    This forum is dedicated to CarPCs and installing them in your car.
    The car audio forum is dedicated to integrating your car audio system with your CarPC.
    For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
    http://www.elitecaraudio.com
    http://www.carsound.com
    http://www.caraudioforum.com
    http://forum.sounddomain.com
    http://www.realcaraudio.com
    http://www.carstereo.com
    http://www.caraudiomag.com
    http://www.termpro.com
    http://www.the12volt.com
    http://www.talkaudio.co.uk
    http://www.caraudiosecurity.com
    http://www.diymobileaudio.com
    http://www.soundsolutionsaudio.com
    http://www.dynamicautoacoustics.com
    et. al.
    There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
    Good luck.
    and now to answer you question--
    a quick google-ing shows that it is impossible-- let me explain:
    parralling all vc's gives you 1 ohm at the amp, series-ing everything gives you 16 ohms at the amp
    parralleling 2-4ohm loads(1 sub) gives you 2 ohms, and adding another 2 ohm series-ed load gives you 4 ohms at the amp(parallel would give you about 1 ohm)
    series-ing the 2-4ohm loads gives you 8 ohms at each sub, parralling them at the amp gives you a 4 ohm load....
    now, according to this link:
    http://www.mombu.com/hdtv/hdtv/t-onl...s-1241780.html
    there is little reason to use both coils-- so just use 2-4 ohm vc's paralleled at the amp for a 2 ohm load.
    now, i am still opposed to 2 ohm setups-- i think that they work everything too hard compared to 4 ohm and higher setups, and it is asking for trouble, but that must just be me...
    edit: one other thing--most questions can usually be answered by a little google-ing, in fact, when i was typing in '4ohm' into google, the response '4ohm into 2ohm amp' popped up, and when i searched for 'use one voice coil on dc sub' the link i posted was the third one down..
    and because the answer was so easy to find on google, it comes with a rant--for the low-low cost of the time it takes for you to make a new post!
    a little time on your part, can help yourself farther than what i just did-- i just gave you the answer, so now, next time you don't want to search, you will just come here for a answer, and no-one learns anyhting from the experience...(the irony is that i am not a big supporter of spoon feeding, but here i am...)
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  1. Wiring two dual-voice coil subs to one mono amp
    By venom889 in forum Car Audio
    Last Post: 12-27-2009, 06:35 PM
  2. Amp into amp or just a new amp?
    By Profozone in forum Car Audio
    Last Post: 12-05-2009, 10:29 PM
  3. FIRST POST!! 4 channel amp + mono sub amp
    By buckemdwn in forum Car Audio
    Last Post: 05-14-2008, 01:13 PM
  4. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 02:41 AM
