Results 1 to 10 of 11
Thread: Small Amp To Fit Behind Screen In Dash?
    Jan 2010
    Hi,
    I have a golf MK6 & am looking for an amp to go behind my Lilliput screen in the dash. I have found the Xtronics amp with built in tuner which would be perfect, but it is quite expensive & they have only replied to one of my emails out of 4 in the last 6 weeks, so I dont feel comfortable with them for any support/come-backs. an anyone recommend anything else for me? It must be four channel & if it is in the UK then even better!
    Many Thanks
    Newbie wazza's Avatar
    Feb 2008
    Australia
    Maybe he is busy
    i have used these guys before and have never had a problem they supplied me 20 of thesses units ea an i and s units
    you need to go to datalex support and attention your emails to LUC if you have any tech issues or if you wish you can all so contact myself i no these units very well and are happy to help you out
    Constant Bitrate almera's Avatar
    Aug 2004
    this is a kit for self assembly;
    http://41hz.com/shop/item.asp?itemid=796&catid=
    FLAC SFiorito's Avatar
    May 2004
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I wonder if you could use an Alpine KTP-445. I know they are designed to plug into >2005 alpine headunits, but I have to think it would have power, input and output connections that you could rewire as needed. Probably contact Alpine and ask.
    http://www.amazon.com/Alpine-KTP-445...9347473&sr=8-1
    Sep 2006
    1 or 2 of these for headunit like power
    http://www.parts-express.com/pe/show...number=300-385
    All you need is a 2 to 4 amp 12V regulated power supply. If your carpc power supply has enough extra on the 12V to supply one you are good to go.
    Jan 2008
    didn't see it mentioned, so i figured i'd add to the mayhem
    some members have used a 'motorcycle amp'(search ebay) in their installs, and have said that they have just as good of audio quality as a factory head unit, though i don't use one, so can't be sure...
    Jan 2010
    Thanks for all the replies! I have already looked at the motorcycle amps, but they are all 2 Channel & only 10!!! so figured they would be 10 Sound quality? I really just wanted something to plug into the existing wiring loom & then plug into my pc, but guess I am being too hopeful......
    Jan 2008
    Quote Originally Posted by mbc0 View Post
    i have seen reports that they are just as good as the factory head unit in sound quality, so even at 10 pounds, they should be decent.
    i have not seen any plug-and-play solutions to a carpc-amp for any cars, so i think you might need to lower your standards a little
    if you enjoy a little soldering project, i have heard excellent things about the 41hz.com amps, and have been meaning to build one, just haven't gotten to it yet. they also offer pre-built units, but what is the fun in that?!?
    Jan 2010
    Just to update anyone interested, I installed a Mcfun 4Channel Car/Bike Amp for 24 & it is fed by a 15 GStar 5.1 usb Sound Card & the sound quality is superb. The only thing I have to do is mount a fan to the amp as it gets VERY hot!!
  1. Replies: 5
    Last Post: 01-18-2010, 05:41 PM
  2. 2gen 4runner aspire one in dash + dual screen
    By jeyventura in forum Worklogs
    Last Post: 11-16-2009, 10:11 PM
  3. 1986 Jaguar XJS - COMPLETED 21 June 2008
    By ThunderStick in forum Show off your project
    Last Post: 06-15-2009, 08:25 AM
  4. Touch screen w/ amp or computer to amp?
    By mike827 in forum Car Audio
    Last Post: 05-13-2009, 05:21 PM
  5. A Really Small 8 Inch Screen?
    By 2002AcuraTL in forum LCD/Display
    Last Post: 01-03-2007, 01:48 AM
