Results 1 to 4 of 4
Thread: 98 toyota 4runner wiring diagram
    Mar 2010
    i have everything(800 amp, 2 1200 subs) hooked up and ready to go the only thing i need is the diagram to connect the car to the new head unit.
    If anyone could post the 1998 toyota 4runner wiring diagram, that would be awesome.
    (i tried everything google, every website you can think of)
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Sometimes you can find vehicle specific wiring at brand/vehicle forums. Otherwise the easy way is to buy the wiring harness for that vehicle. The wiring harness will plug into your factory plug and the wiring color should match up to the wires coming out of the new headunit. Best buy carries these harnesses or you can order online at many places.
    Like this, make sure the plugs look the same.
    Metra 70-1761
    http://www.amazon.com/Metra-70-1761-...=pd_sim_auto_2
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by No_Bass View Post
    If you want to cut the factory plug off, (which I don't recommend, use a wiring harness like mentioned above) Here is a link to the factory wiring diagram: http://www.the12volt.com/installbay/...tail/2027.html
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Jan 2008
    Quote Originally Posted by Snootch View Post
    just always be careful following online wiring diagrams-- when hooking up my alarm, i found 3 different wire guides, and some of each had different wire colors for different features-- none of the diagrams were exactly the same as my car.
    try to test the wire combos as much as possible with a volt meter first.
  1. Replies: 4
    Last Post: 05-06-2010, 09:42 PM
  2. Wiring Diagram
    By MichaelPlace in forum Newbie - Proposed setup
    Last Post: 04-12-2009, 06:09 AM
  3. Dead Xenarc 700TS - Wiring diagram anyone?
    By Cancerman in forum LCD/Display
    Last Post: 03-29-2009, 09:22 PM
  4. emerson 8100 wiring diagram???
    By etrik in forum General Hardware Discussion
    Last Post: 02-11-2007, 12:40 PM
  5. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 03:35 PM
