Results 1 to 10 of 14
Thread: How to hook up extra battery?
    Jul 2009
    I was thinking about buying a capacitor to help with some voltage drops that I am having, but after reading some threads on here, it seems like that is a no-no. I have seen recommendations to buy a small AGM 12v battery. That sounds like a good idea but my question is can I hook it up so that it stays charged constantly like my car battery? It seems like it would be a pain if you had to charge it everytime it went dead. I would be running my carputer, mono sub amp, and 4 channel amp off of it, so what size should I get?
    Jun 2005
    Burlington
    I hooked my second battery up in parallel after the car's relay. I have doubled my PC's runtime with the engine off.
    Jan 2006
    Michigan
    second battery
    I have been reading a lot of threads regarding installing a second battery to power the carputer and other high power accessories with the vehicle off without running down the main start battery. Although most of the ideas are pretty good, a number of points have been missed:
    1. The alternator
    If you have a 'normal' car or light truck with a standard alternator, it will quickly die when the second battery is installed. The alternator's voltage regulator was designed by the electrical engineers for your car with normal loads. Adding something like a second battery will quickly exceed the capacity of the alternator if that battery is discharged.
    2. Battery isolation
    Although you can use a simple relay to connect the two batteries, a battery isolator is the best way to go. This will not only keep them separate when the engine is off, but provide some additional over voltage protection on both sides of the isolator.
    3. Mixing the type of batteries
    This is a big mistake that will cost plenty in the long run. Most people use a sealed battery (example: AGM) so it can be placed in the passenger compartment or trunk. An AGM battery is still a wet cell battery and it will vent if over charged. If it begins to vent, it will vent hydrogen and sulferic acid mist into the compartment where it is stored. The best place to put these batteries is still in a vented compartment.
    4. Connecting battereis of different sizes and ages
    This is another big mistake. When the alternator is sending out charge current, it doesn't care where it is going. All the regulator sees is a load. That load is below 12 volts and the resistance 'looks' like a battery, so it pumps out power. If you have two batteries of different sizes and/or ages, then the weaker/smaller one will take most of the charge current. The other issue is if one of the batteries has a weak cell, then it will pull on the good battery even during the charge cycle. Using a true isolator will help balance this load out.
    Before you flame me to bad, I deal with this every day repairing damage caused by customers who wire batteries and chargers incorrectly in their RVs. 12 volt systems are not complicated if you follow a few simple steps.
    1. Know your supply and loads
    Before installing any high drain system, make sure your electrical system is up to the task. If your alternator is more than 3 years old, then it is probably time for a new one before you start this upgrade. Same holds true for the battery(ies). If you are upgrading power, then upgrade to a larger alternator and replace the main start battery at the same time. At this time, install your second battery, isolator and high quality cables to handle the power.
    2. Plan all electrical runs before getting out the wire cutters.
    Know where everything electrical is in your vehicle and how it is connected. This will help prevent problems with power (and help with those ground loops).
    3. Test Test Test
    Install each component one at a time to make sure it doesn't disrupt the electrical system of your vehicle.
    4. Buy a good VOM, clamp on amp meter and bettery tester
    These tools are great. Remember you not only need to know the voltage, but the amp draw. Example: If you have a 700 ah (amp hour) battery, and your draw under full load is 100 amps, then you could (in theory) run the system for 7 hours before depleting the battery. This also opens the opportunity to design a system to shut the system down after so many amps have been pulled through. You will also need to understand ohm's law, watts law and the inverse amp law.
    I love my truckputer and really enjoy the challenge on making it work. I'm not very good with fabrication, but I like 'whats under the hood' much better.
    Good luck to you all and have fun,
    DNR
    Apr 2010
    here is what i have been putting to gether in my head the past week or so.
    install second battery somewhere. place a battery seperator in between both so that it will regulate power. charge them while the car is running / seperate them as need be for overcharging / and i believe some seperators link upon starting if too much power is lost in the primary. install a switch to link them for specific short instances such as using a winch... etc...
    then i want to hook up amps( 4 channel and mono), car pc, lcd, and any other electronics i decide like cb, ac/dc inverter... you get the idea... well hook them up to the battery and then hook up the items that require an ignition on wire, hook them up to that so they will shut on and off via the ignition key and be powered by the aux. battery.
    the tricky thing is that i want a second battery primarily to preserve the main/original battery for starting purposes. but... what if i want to run the pc and amps to listen to music with the key out because i don't want to drain th emain battery with all the other things that start running when the key is in...
    i will have to make an alternate "ignition switch" with a regular on/off switch. the switch will be in the line of the specific item's ignition detection wire and the aux. battery itself. so i could technically flip the switch and the devices turn on as they would with the key in....
    THERE IS A PROBLEM WITH THIS IDEA THOUGH... If i flip the switch on with the key in, the ignition detection wire from the vehicle is off the main battery and if i flip the switch on, it will link th e2 batteries.... i don't know how to get around this... would only happen if the switch is flipped while the key is in though.
    I just want to have the option to run some things with the key out but then they will run with the vehicle still running and have all the features of off with the key on with the key.
    would only happen if the switch is flipped while the key is in though if i wanted the devices to keep running after i take the key out instead of waiting for them to shutdown and then come back up.
    Jan 2006
    Michigan
    Two batteries
    You are on the right track.
    I'm going to draw a picture and post it. Is easy in a drawing, but hard to describe.
    DNR
    Apr 2010
    quick drawing without the extra switch i was talking about. this would allow everything to be powered by the aux. battery but will turn on with the key in the ignition and shut off whe you take the key out. i still gotta find a way to allow "JUST" the things to turn on or keep running when the key is taken out.
    [IMG][/IMG]
    Jun 2007
    St. Louis
    I don't mean to thread crap - but I'm in a similar situation with a dual battery setup. My car is a pain in the arse though. It's a 2004 Maxima, and the alternator apparently "doesn't work with battery isolators". The plug on the alternator is simply 2 wires, black and white or yellow.
    Which leaves the option of using a relay connected to the ign-on wire.
    Not sure if your car falls into that category or not, but it's something to look into before you buy equipment.
    Raw Wave
    Nov 2009
    If you have a typical alternator's charge light circuit, it's EASY!
    Connect an SPST (on-off) relay with its solenoid (terminal #86) to the L or D+ from the alternator (D+ for single wire alternators; L for 2 or more wired alternators - same thing; different labels).
    Ground the other #85 end.
    Connect the main battery through a fuse (or better still - a circuit breaker) to the relay (#30) and the relay output (#87) to the second battery via a fuse (or CB). The fuses/breakers should be as close as practicable to each battery.
    Only after charging begins does the relay energise and close the contact to connect the batteries.
    You may already have a similar relay circuit - older carby vehicles with electric fuel pumps often used a similar circuit, and some used the same to control electric chokes, fuel cut-offs etc.
    If you have such a relay, you could power the battery relay from that (though it might come on during cranking as part of the carby-priming etc to enable starting).
    Most alternators should be able to power a typical automotive relay of down to ~60 Ohms relay-solenoid/coil resistance (ie, ~200mA). The D+ or L circuit will typically sink 1A of current (ie, ground various dash bulbs etc) but that doesn't mean it can provide 1A at 12V....
    If your battery relay requires a large actuating current, it'd be best to have the D+/L turn on a smaller relay which can then power the larger relay.
    The size of the relay, fuses & cable depends on what you expect the 2nd battery to draw. I use a 70A (or is it 140A?) relay with 50A circuit breakers and ample wires size.
    See my posts under 2nd car battery and Smart Battery Isolator.
    The circuit is....
    It won't wreck your alternator unless you have a bad one. (They are more likely to blow after jumpstarting if the jumper battery is pulled off to fast - as I found out during my recent Bosch experience!)
    And since the batteries are not paralleled when idle, there are no matching issues - just the usual periodical battery condition checks (Read: Get a dash voltmeter!)
    And a low-voltage cut-out will preserve the 2nd battery.
    Relay(s) might cost ~$10-$20. A low-volt cutout ~$20. Much cheaper than voltage-sensing relays, and stupid diode isolators.
    And you can probably ignore most claims regarding current sharing - it's not an issue (unless you have a collapsed battery - hence the periodical checks, or a temp sensor) - a vehicle's battery system is a constant voltage system by design - the currents look after themselves. (And if someone says they regulate the current to each battery, ask them how & let me know.)
    Apr 2010
    any ideas on how to make a master override for the equipment in the blue boxes? a switchthat icould flip before i take the key out and the equipment in blue boxes would stay running unless i flip the switch off.
    Raw Wave
    Nov 2009
    You can make a self latching relay using a normal relay and 1 or 2 switches.
    The first switch is a momentary-on power-on that latches the relay (or keeps it energised).
    To turn it off, either break the main power, or a second normally-closed switch can be used/pressed to turn it off.
    I recommend adding 2 diodes depending on the power being switched (IN4004 etc = 1A etc; ~20c each).
    So a push button(s) plus diodes plus $5 - $10 for the relay (for up to say a 60A load; maybe $20 for 200A etc).
    A commercial low voltage cutout can also be added (~$20). (I guess I could make one for $1-$2 in parts, but international commercial products are universal & repeatable.)
    If interested, reply else PM.
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 11:45 AM
  2. 2nd battery + computer controlled lighting
    By jparks27 in forum Show off your project
    Last Post: 06-02-2006, 08:52 PM
  3. Replies: 1
    Last Post: 06-27-2005, 08:16 AM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  5. Problem with tank battery - any good Plan B?
    Last Post: 06-14-2004, 09:10 PM
