Results 1 to 10 of 13
Thread: USB to Phono with Female-Female USB Adapter
    Jul 2007
    I'm trying to connect my mp3 player via its USB to my car's aux/2xphono input. I was interested in knowing if anyone's tried the USB to phono cable with a Female-Female USB adapter. Why would this not work?
    Jan 2008
    Because USB and audio are 2 completly different formats- USB is digital, audio is analog
    Jul 2007
    Thanks I needed that!
    I appreciated the prompt response soundman98, but I was hinting at knowing if there's a DIY kit or Aux box modification (it's an aux box from a company called PIE).
    Jan 2008
    well, quit hinting
    a quick search found that PIE makes aux inputs for factory decks, but that is about all that i can tell-- i am a little lost at what you are looking for.
    Jul 2007
    USB - Aux Converter
    Many current DVD players have USB inputs which play music/video from flash drives and have optical/phono plugs as outputs. I was hoping someone at mp3Car would have had DIY instruction to achieve this, minus the DVD player. Ebay has them as "Digital sound processors".
    Jan 2008
    i haven't seen anything like that-- i think that you can buy a unit like that and modify it to work for you than it would be to build your own.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by mpman View Post
    The "car's aux/2xphono input" is an audio input.
    You're MP3 player headphone jack is an audio output.
    The connector to use is a 3.5mm male to male stereo audio cable.
    Jan 2008
    Quote Originally Posted by Curiosity View Post
    i think he wants to play media off of a usb drive, or sd card, but his car only has a analog aux input..
    Jan 2008
    get a mp3 player, you cannot connect usb to aux. but you can get an mp3 and cable to connect the mp3 player to you audio in on your stero
    Jul 2007
    Some links
    It seems there are no USB soldering tinkerers here, but I've a attached product. I already have the USA-SPEC DF-Toy CD interface/aux input for a Toyota. Basically, has anyone here soldered a USB input to this unit or have links to someone that has worked on such soldering projects
    http://www.usaspec.com/product.php?ProductID=17
    Thanks,
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Replies: 96
    Last Post: 11-30-2006, 08:16 PM
  3. Bytecc BT-200 USB 2.0 to IDE Adapter power?
    By hauler34 in forum Input Devices
    Last Post: 11-07-2006, 02:02 PM
  4. Slimline DVD + IDE adapter + IDE -> USB adapter = no drive in Windows?
    By WiCKeD 5.9L in forum General Hardware Discussion
    Last Post: 08-04-2005, 10:49 PM
  5. self powered or bus powered for USB wifi adapter
    By jagsnag in forum Wireless Communications
    Last Post: 07-28-2005, 07:49 PM
