Results 1 to 4 of 4
Thread: cd/dvd stereo head unit turning on and off when i hit brake?help!!
    Oct 2006
    hi everyone i have a question for the experts.i recently purchased a valor dd-858w. wired it up and everything looked fine powered up, sound from the speakers.when i went to drive with the radio on i hit the brake and the stereo turned off and then back on.this happened off and on when i hit the brakes.what could cause this to happen.i also didnt wire up the parking brake since im not worried about watching dvds.but would this cause this problem??does anyone have any advice on what this problem could be.any and all help would be greatly appreciated
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    i had a similar problem with a unit similar to yours, did you hook up the wire for the rear cam as that needed a wire to ground for it to function, i ended up having that problem go away might be worth a try SNO
    Oct 2006
    no i didnt hook up the reverse wire since i dont have any rear camera installed.would that make the radio turn on and off when i hit the brake.
    Nov 2009
    Keswick,On Canada
    wouldn't hurt to try SNO
