Results 21 to 30 of 32
Thread: 2, 2ohm Dual Voice coil subs to mono amp
  1. #21
    Jul 2010
    Well, I'm back. i got everything hooked up and running. Sounds great....but..... when i turn the stereo up to about 24 or 25 on the volume, and it hits a big bass note, the amp stops breifly. the lights on it are all still on, just no sound coming from the subs. i turn the volume back down and it works again I have wired the voice coils in series and the subs in parallel and hooked them to the amp as the instruction said. i have checked all wire connection and i am banging my head on the hood of my truck trying to work the problem out. any suggestions?
  2. #22
    Nov 2006
    Rubidoux, CA
    Where do you have the sensitivity on the amp set to? If it's too high, it will end up peaking out as you turn your head unit up. You would ideally start with the sensetivity turned all the way down, crank the stereo, and dial the sub amp up to get a good match with the rest of the system.
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
  3. #23
    Jul 2010
    Ok.I havent done what you suggested yet. but now the amp actually shuts off not (no lights are on, on the amp and no sound through the subs. i turn the unit off for about 20 minutes and then on again, it works for about 10 minutes , starts cutting out and then goes off completely. As soon as i have time to tinker with it, i will turn the sensetivity down and try it. it does it mainly when it hits some really strong bass notes. im probly gonna take it out and go back over all my wiring,,, again.. Thanks guys for your help so far!
  4. #24
    Nov 2006
    Rubidoux, CA
    if it's shutting down, then it is either drawing too much load to the speakers (probably shorted wiring somewhere), or it is faulty and 'thinks' it's drawing too much load.
  5. #25
    Jan 2008
    faulty somethin...
    check for pinched rca's(i cooked 3 amps with this mistake in my last car..), loose wires.. and also try to check that the subs voice coil is fully intact-- if it is starting to fall apart, this could also cause it..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  6. #26
    Jul 2010
    The back of the head unit has two rca plugs attached to wires ( so the wires come out and then there are 2 female ends kinda dangling there) to hook to subs only. the wires appear to be crimped. can that be fixed?. the wired come out of the head unit casing, nothing to disconnect from the head unit to replace them. I have went over and over all my wiring and nothing is touching something that it shouldnt. and the subs are wired correctly (checked them about 100 times) .
  7. #27
    Nov 2006
    Rubidoux, CA
    Shorted inputs on the amp shouldn't cause the amp to cut out (the sound would, but the amp would stay running)
  8. #28
    Jan 2008
    if you suspect the headunit try either a different head unit, or a different sub/amp combo-- that would definately narrow it down
    HID retro--100%
  9. #29
    Jul 2010
    Found the problem. On the back of the head unit where the rca plugs are. the plugs had seperated slightly enough to be up against some metal under the dash. i plugged them in snug, taped them together and BOOM I have a working system now. Thanks everyone for your help!
  10. #30
    Sep 2011
    Same amp
    Hi. I have the same amp! I have a single dual 10" 4ohms kicker. the amp pushes out 900 watts at a 2ohm load. How do i wire this to the amp?? Am i soposed to come outta the box with 4 wires? the kenwood book says thats how i would but the kicker book says differant
  1. Replies: 38
    Last Post: 11-30-2010, 05:04 AM
  2. 1000rms 2ohm amp mono block
    By james1985 in forum Car Audio
    Last Post: 03-15-2010, 08:44 AM
  3. Hifonics amp: Mono signal required
    By jrwmu31 in forum Car Audio
    Last Post: 12-26-2007, 10:51 PM
  4. Replies: 0
    Last Post: 09-25-2007, 10:56 PM
