Results 1 to 4 of 4
Thread: wiring amps
    Aug 2010
    wiring amps
    Hi gang i'm new here Help please I have 2 subs kicker 12" / 2 sub amps BP150.1 / 2x P80.4 and a brand new head unit kenwood, the amps are already wired together but some RCA's are undone is there some kind of diagram, i need to wire all of this together the right way. I already know where the subs are hooked up on the sub amps ,the hardest part for me would be where all the RCA's go
    Nov 2006
    Rubidoux, CA
    I guess the canned response would be that you're not really at the right forum. This forum, while yes, it DOES have a car audio section, is geared towards car-pc's. There are other, much more suitable boards to discuss help on these matters. That's not to say someone won't chime in with an answer, but there are others on other boards that are more likely to help.
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    PanamaCityBeach/NewOrleans
    http://www.the12volt.com/
    may be a better place to look for help.
    IMHO that sounds like an issue not suited for a forum. is it safe to say you spent a pretty penny for all that? then protect your investment and take it to some one that can do it. if its just redoing the wiring your local sound shop should not charge much.
    Jan 2008
    i tend to agree with sleepyzomby-- take it somewhere where they know what they are doing, or take the time to research what you are doing...
    a simple help post is not enough for you to thoroughly understand what you need to connect, and more importantly, WHY you need to connect it there...
    car audio is a huge area, and there are tons of posts on many forums on why things are done-- if you have a serious interest in car audio, it is best to do the research..
  1. AWG wiring issue on M2-ATX...???
    By Nazx in forum Newbie
    Last Post: 03-31-2008, 08:03 PM
  2. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  3. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  4. Wiring 2 AMPS?
    By 3onDubs in forum Car Audio
    Last Post: 08-31-2005, 01:32 PM
  5. Amps Protecting at high volumes
    By kdunn926 in forum Car Audio
    Last Post: 08-30-2005, 10:14 PM
