Results 1 to 3 of 3
Thread: one channel on amp isnt working right.
    Sep 2010
    hello,
    I have a Boss D500.2 2 channel amp 1000watts.
    and 2 12" pioneers subs.
    Boths subs work properly.
    The right channel on the amp works fine
    but the left channel doesnt, itll produce sound on the sub connected to it but it is very very low.
    i hooded up both subs to the right channel and they both play properly.
    and i even briged one sub to the amp - left channel using "positive" and right channel using "negative" and it worked fine. i also hooked up the other sub and it worked properly.
    so im guessing the left "negative" isnt working properly?..
    any ideas?
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Im sure there is a nice car audio forum out there that can help you with your problem, but it seems like your amp is stuck in mono (right channel only)
    Sep 2010
    stuck in mono...
    but bridge mode works?
    or is that because its stuck in mono and it disables the left negative but keeps the left positive live?
  1. Can a 2 channel amp fade?
    By macminivan in forum MacCar
    Last Post: 11-17-2009, 05:08 PM
  2. FIRST POST!! 4 channel amp + mono sub amp
    By buckemdwn in forum Car Audio
    Last Post: 05-14-2008, 02:13 PM
  3. Replies: 67
    Last Post: 10-15-2006, 09:35 PM
  4. 2 Channel amp no headunit
    By skippy911 in forum Car Audio
    Last Post: 10-01-2005, 01:14 AM
  5. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
