Results 11 to 20 of 26
Thread: What is causing this noise from my sub? (Clip included)
  1. #11
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Quote Originally Posted by OldSpark View Post
    FYI - that voltmeter fluctuates a lot, and gets over 14.4V etc.
    What is it monitoring?
    If it's ignition or dash, make sure your ground connections (chassis-engine-battery-) are properly connected and sized - especially if the alternator is sensing battery voltage!
    Huh?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  2. #12
    Raw Wave
    Nov 2009
    Sorry - it is an AFM. It looked like a typical bling voltmeter....
  3. #13
    Jan 2008
    ? i re-watched the video a couple of times-- it is a black screen with the noise he is referring to-- i don't see anything..
    i agree on the other points, it sounds almost like either a ground loop, or incorrect crossover setting..
  4. #14
    Oct 2003
    Poland, OH
    I don't have a mic hooked up and even with all levels muted it still happens.
    The AMP is a Kicker zx350.2. I don't have any separate crossover.
  5. #15
    Jan 2008
    ok, what are the crossover settings set to on the amp?
  6. #16
    Oct 2003
    Poland, OH
    Before I go look. What *should* they be so I can change them if incorrect. Thanks
  7. #17
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Most subs should not see anything above 100 Hz, maybe 120 Hz
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  8. #18
    Oct 2003
    Poland, OH
    Crossover is set to LO and 110 Hz.. It was making the noise even without Windows being loaded.. Also, no cell phones were in my truck either (I've heard those causing sound issues before).. Should I turn the frequency down?
  9. #19
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Try removing the inputs from the crossover alltogether, Is the noise still there?
    Try bypassing the crossover, go straight from you head unit or computer into the sub, with no other signal. In other words dont play music or anything, just see if the same noise is there.
    That noise is well above 110 Hz so should not make it through the crossover.
  10. #20
    Jan 2008
    110 should be low enough, though you can try to turn it down to 80, or even its lowest setting to check if it willl remove the noise..
    did you happen to do anything to the amp recently?
    i had a issue similar to this a couple of months ago when i was trouble shooting my own ground loop issues, and tried "lifting the ground" by applying power to the negative rca input briefly-- it resulted in messing up the amp-- so it output a constant tone..
  1. Found noise source. Help me find cure.
    By Punky in forum Car Audio
    Last Post: 01-16-2008, 06:56 PM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  3. Terrible static noise on SP13000 (internal audio)
    By BlackStealth in forum Newbie
    Last Post: 05-15-2006, 02:44 PM
  4. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 02:33 PM
  5. Power noise - the horror!!!
    By mtmsol in forum Power Supplies
    Last Post: 06-19-2001, 10:13 PM
