Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: What is causing this noise from my sub? (Clip included)
  1. #21
    Aug 2010
    Sounds like line noise from the PC (assuming you are using a car pc and the Mobo's analoque out connections).
    From sound card driver zero all channel outputs except the sub channel. If it is audible and varies with the sound card sub out channel gain then this is the most likely cause.
    I had similar issues using the analoque outputs for on Home theater PC the only solution I found was to use the SPDIF digital output directly to the external amp.
    In a car the only to remove this is to process the outputs with a DSP module such as the Alpine PXE-H650 are other setups.
    Another possibilty would to use an external sound module such as Creative USB Xi-Fi card and feed the Stereo rca oututs into an equalizer that then filters the Sub channel.
  2. #22
    Nov 2010
    check the ground loops
  3. #23
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    So I haven't done anything yet because I haven't had time but the sound is getting worse and a lot more frequent.. Here is another clip:
    [media]http://www.youtube.com/watch?v=G4Js9k1x_EU[/media]
    With it getting worse over time do you think that points to the SUB itself?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  4. #24
    Raw Wave
    Nov 2009
    Try here and the following suggestions.
    There may be other suggestions earlier in that thread.
    I'd like to copy and paste, but I just couldn't be bothered.
    If I have replied in haste & misinterpreted, I apologise.
  5. #25
    Oct 2003
    Poland, OH
    Quote Originally Posted by OldSpark View Post
    So you linked a post in my own thread?
  6. #26
    Raw Wave
    Nov 2009
    Yes.
  1. Found noise source. Help me find cure.
    By Punky in forum Car Audio
    Last Post: 01-16-2008, 05:56 PM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 02:36 AM
  3. Terrible static noise on SP13000 (internal audio)
    By BlackStealth in forum Newbie
    Last Post: 05-15-2006, 01:44 PM
  4. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 01:33 PM
  5. Power noise - the horror!!!
    By mtmsol in forum Power Supplies
    Last Post: 06-19-2001, 09:13 PM
