Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: What is causing this noise from my sub? (Clip included)
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I have a strange noise that comes out of my sub but it's not all the time.. It's also not every day.. I had thought it may be my phone but if that was the case I would think it would be more consistent as I always have my phone with me and it's always syncing..
    Anyone have any ideas what could be causing this?
    http://www.youtube.com/v/Q0apEdRC6-0
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Throw in a different sub and see if it still occurs.
    Oct 2003
    Poland, OH
    Could that be it? I don't have another sub to try...
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    It almost sounds like the noise a ported sub makes when the port is sized too small.
    Oct 2003
    Poland, OH
    No I don't think it's anything with the port. It's definately a sound from the sub. Almost like Morris code.
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    sounds like feedback from microphone. have you muted line in and mic just to see? just my 2 cents SNO
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    What kind of cross over and amp are you using. It is a higher pitch sound than a cross over should allow to even get to the sub, so it is either on the output of the crossover or the amplifier, or interference in the power supply cabling to either. Do you have another amp you can try with the sub and crossover. If it is still there, then it would be the crossover. If it is not then it would be your amp.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by SNOtwistR View Post
    Thats what it sounds like to me too...... Lie the mic is too close to a speaker and causing feedback. Have you checked to see if you mic input is muted or not?
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
    Raw Wave
    Nov 2009
    FYI - that voltmeter fluctuates a lot, and gets over 14.4V etc.
    What is it monitoring?
    If it's ignition or dash, make sure your ground connections (chassis-engine-battery-) are properly connected and sized - especially if the alternator is sensing battery voltage!
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Does it make a "pop" when you turn the volume all the way to zero or turn off the HU? It almost sounds like your HD is causing the interference, the frequency is pretty high, do you have the amp set to full, highpass or lowpass, you might be able to eliminate that sound with your amp if you set it to lowpass and adjust the frequency to 50hz or lower
  1. Found noise source. Help me find cure.
    By Punky in forum Car Audio
    Last Post: 01-16-2008, 05:56 PM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 02:36 AM
  3. Terrible static noise on SP13000 (internal audio)
    By BlackStealth in forum Newbie
    Last Post: 05-15-2006, 01:44 PM
  4. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 01:33 PM
  5. Power noise - the horror!!!
    By mtmsol in forum Power Supplies
    Last Post: 06-19-2001, 09:13 PM
