Results 1 to 10 of 14
Thread: distribution block and grounding?
    Sep 2006
    hey guys do you need to run a distribution block for more then 2 amps? or can u hook them straight to the battery?
    how about for the remote wires from the HU do you need a distribution block for them?
    one last question can i ground both amps to the same point on the car? or do they have to be separate?
    thanks guys
    Elsewhere
    No.
    No.
    Yes.
    You haven't said anything about your PC.
    How about the Wiki?
    Sep 2006
    sorry darque just to confirm... so i can terminate both +tive wires at battery and it will be fine?
    i am not running a PC yet.. i just got a new set of components + amp and just trying to figure out how to wire it up with a AMP + sub already installed
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You don't need a distribution block unless you are...well...needing to distribute power to multiple locations.
    You can connect direct to your battery if you want, but you didn't mention adding a fuse inline. You'll want to do that close to the battery so if the wire accidentally grounds against, say, the firewall where it passes into the cabin, you won't have a direct short from battery to ground.
    At that point, the wire becomes the fuse and if conditions are right, it will heat up until either the insulation catches fire or something nearby does. If you fuse it near the battery, the fuse will blow and nothing will happen.
    Want to:
    Sep 2006
    sorry buy i do have a inline fuse ready to go on the wire.
    well i am distributing power to 2 amps so i guess that does qualify?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Holy crap! I misread your post. I thought you were asking if you needed to use a distro block if you were running more than 2 amps of *electricity*. Not two amplifiers!
    You don't have to have a distro block for 2 amplifiers but make sure you have an inline fuse on both wires no more than a foot from the battery. That will protect the wire. I presume the amps themselves have fuses on them to protect the amplifier.
    Want to:
    Elsewhere
    Still haven't read anything about your PC, krayzie...
    How about the Wiki?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    DP he said he wasn't running one yet.
    RevFE
    My Shop
    Jan 2008
    the main reason for distro blocks is consolidation-- it is a pain to run wire from the front to the back of the car, whereas, with a distro block, you can run just 1 wire..as long as the power you need is taken into consideration.
    it is usually recommended to try to ground multiple amps to the same spot, though, it is also usually recommended that you try to ground a amp within 12in, so the 2 will not always go hand-in-hand..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Sep 2006
    yeah DP sorry i havent gotten around to my PC yet im just trying to get the audio down first,
    i have 2 x 200W RMS amps to 1 sub 12inch kenwood DB+ and the other to JL c2 600 splits
    do you think i can run an 8 gauge to dist block then to 2 8 gauge?
    or should it be 4 dist block 8 - 8'
    thanks again!
  1. Questions about grounding, fuses, amps, and whatever else I don't know.
    By thejavabuddha in forum General Hardware Discussion
    Last Post: 08-23-2009, 10:55 PM
  2. Power wire and distribution block setup
    By skiWVUxtm in forum Car Audio
    Last Post: 03-06-2007, 08:11 PM
  3. Most bizzare grounding situation...
    By blessani in forum Power Supplies
    Last Post: 07-21-2006, 01:18 PM
  4. Grounding Question what size wire
    By michaelrj9 in forum Car Audio
    Last Post: 08-22-2005, 03:54 PM
  5. Wiring and terminal block recommendations?
    By omehegan in forum Car Audio
    Last Post: 07-21-2005, 08:25 PM
