Results 11 to 20 of 21
Thread: Suggest an internal amplifier please!
  1. #11
    Jan 2008
    the specific amp that you linked to before should be fine connected to car power, though it wouldn't hurt to connect it to a regulated power supply..
  2. #12
    Jun 2007
    Boston MA
    what are power requirements of this amp - it doesn't say anywhere on the website? the amp is 4x50w, 4x100w peak - but that doesn't mean it consumes 200W of power on average and 400W peak, right? So how much power should be dedicated to the amp?
  3. #13
    Jan 2008
    you could try to email 41hz.com for a specific answer, or you could also check other commercially available 50x4 rms amps for their amperage input.. (for jl's xd series 50x4w rms amp, they recommend a 40 amp fuse)
  4. #14
    Constant Bitrate tibimakai's Avatar
    Feb 2005
    San Pedro, USA
    I have a similar project going on and I'm also interested in this amp.
    I would like to find out how much power I would get with the pc's output? (single core Intel Atom board)
  5. #15
    Jan 2008
    Quote Originally Posted by tibimakai View Post
    do you mean audio power, or the power it takes to make the amp work?
  6. #16
    Feb 2005
    San Pedro, USA
    audio power
  7. #17
    Jun 2007
    Boston MA
    Processor speed does not affect the sound output levels. I'm really not sure what you mean.
  8. #18
    Feb 2005
    San Pedro, USA
    like stereos have 2V, 5V outputs, how much output does have a motherboard audio output port(at the headphone jack)?
    it will be enough for a decent power output from the amp9?
  9. #19
    Jun 2007
    Boston MA
    The amp is there to amplify a low power signal. It can come from an ipod or a motherboard. I don't know much about amps, but I don't think amps have a minimum input level requirements. I haven't tested my AMP9 yet, but I can let you know how it works when I get around to it.
  10. #20
    Jan 2008
    audio power
    it should output 60w rms x4 channels..
    most amps have a gain control to adjust for different input levels, but i don't see it right away in the board pics.. according to the data sheet, it appears to auto-scale..
    nivanov, i know it was in a different thread, but after looking at the data sheet for the tripath chip used in the AMP9, i noticed a couple features you were having trouble with:
    datasheet:http://pdf1.alldatasheet.com/datashe.../TAA4100A.html
    "Pop-Free startup and shutdown"
    and "pin 11: 5VGEN, On chip 5V regulator bypass capacitor connection" not sure if this means that it generates it's own 5v signal for the other stuff, or if it is a filter circuit for a 5v signal..
  1. BMW E60 install and I-Bus retrofit....tricky
    By Craggy in forum General Hardware Discussion
    Last Post: 11-17-2010, 05:06 AM
  2. Wiring two dual-voice coil subs to one mono amp
    By venom889 in forum Car Audio
    Last Post: 12-27-2009, 07:35 PM
  3. Why is my amplifier grounding out on my computer?
    By Maheriano in forum Power Supplies
    Last Post: 08-31-2008, 05:20 PM
  4. Taking internal amp out of head unit.
    By stonestatue in forum Car Audio
    Last Post: 01-19-2007, 02:28 PM
  5. SoudBlaster PCI128 Do I need amplifier
    By Eddy25 in forum General Hardware Discussion
    Last Post: 10-07-2002, 10:57 PM
