Results 1 to 4 of 4
Thread: 4-Channel Amp Question
    Dec 2010
    Hey guys i know this is a really basic question but i'm getting split stories from everywhere i ask and i need a definite answer.
    I have 4 Kicker 08KS6930 KS-Series 6-Inch x 9-Inch 152mm X 229mm 3-Way Speakers
    They run at 100 Watts RMS at a 4 ohm impedance.
    I also have a 4 channel amp (Which claims to power all 4 speakers in your car) and states it runs at 90 x 4 watts rms at a 2 ohm impedance. I asked the crutchfield advisors and they said it would not work, it would only work at 4 ohms. But at 4 ohms it only runs 175 x 2 How is that possible that i would need 2 four channel amps to power my front and rear speakers? That didn't seem logical so i read some more and found people saying they hooked up the amp to 4 speakers and after looking at the speakers it stated they ran at 4 ohms. So you see my confusion? I would greatly appreciate it if you could answer this question for me.
    Will the Kicker 08ZX3504 amp power the 4 speakers stated above?
    Thank you so very much for your replys
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    4-channel car amplifier
    60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
    175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
    2-, 3-, or 4-channel output
    variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
    variable bass boost (0-18 dB at 40 Hz)
    top-mounted controls
    CEA-2006 compliant
    preamp and speaker-level inputs (speaker-level input requires an optional adapter)
    fuse rating: 20A x 2
    8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
    13-1/2"W x 2-3/16"H x 9-5/8"D
    warranty: 2 years
    A quick google search of your amp says yes, you'll have 60 watts per at 4 ohms
    Jan 2008
    i used to think that crutchfiled was a great place with knowledgeable associates for everyone to start messing with car audio-- though i am really starting to doubt this after some of these complaints...
    Dec 2010
    Las Vegas
    Quote Originally Posted by soundman98 View Post
    We don't really know what the OP asked/told Crutchfield; they may not have known what specific amp it was or were told something confusing (e.g., "hey man my amp can only do 175 watt x 2 channel at 4 ohm... will this power my four speakers?"). They're an authorized dealer for all their stuff so I tend to give them the benefit of the doubt. <shrug>
  1. Amp mouting question...
    By kenjancef in forum Car Audio
    Last Post: 06-04-2009, 03:06 PM
  2. Ipod to 5 channel amp, no head unit??
    By spinerep622 in forum Car Audio
    Last Post: 05-27-2009, 11:10 AM
  3. Replies: 67
    Last Post: 10-15-2006, 09:35 PM
  4. Bazooka 4 channel Amp
    By tiggs in forum Classified Archive
    Last Post: 06-03-2005, 11:52 PM
  5. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
