Results 1 to 10 of 11
Thread: Multiple simultaneous differing audio signals?
    Constant Bitrate Lincolnman's Avatar
    Nov 2008
    Fargo, ND
    Okay, was that title confusing or what?
    To clarify, what I am talking about here is three separate audio signals playing at the same time. Let's say that there are three monitors, all displaying different things for different people but running off of one CPU.
    Monitor one is being used for a music player. The audio signal associated with this is being run through a processor for EQ and alignment (per driver) and then run to six speakers. This would be, say two high/full range, two mid/bass, and two bass.
    Monitor two is running a movie, and this sends a signal to a headphone jack.
    Monitor three is playing a video game, and this is to a headphone jack like monitor two was.
    Is it possible to run three audio signals like this all at the same time? I apologize for not searching more, but I am at a loss as to what to even look under... if someone has asked a similar question before a link to that is just fine.
    Electronics work on magic smoke - don't let it out.
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Quote Originally Posted by Lincolnman View Post
    Absolutely...with three sound cards. I'm pretty sure OM supports independently assigning audio source and output to individual screens, and Centrafuse 3.2 will too. I don't know about RR.
    I don't believe there's anyway to do it with only one sound card, though.
    VegasGuy
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    The topic your referring to is called multi-zone. Searching for that should give you a good bit of info.
    Some Links:
    OpenMobile 0.5.0.14 Released (11/27/09)
    Truly independent multi-zone
    Also note-the term multi-zone is sometimes improperly used for the following:
    * 2 screens and 2 audio outputs should be known as Dual Zone
    * 2 screens but only one audio output should be known as twin-view or dual screen
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by VegasGuy View Post
    VegasGuy
    Actually there have been some users able to use 5.1 or 7.1 sound cards as multiple output devices. It definitely takes a bit of work and its not something you'll find a step by step guide for but my recommendation would be:
    http://software.muzychenko.net/eng/vac.htm
    Of course like VegasGuy said...multiple sound cards is really the best way to do it.
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    or Live/Audigy1/2 card with kxProject driver, it gives 3/4 independent sound device in windows
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Nov 2008
    Fargo, ND
    Quote Originally Posted by FPeter View Post
    Man, I started reading about KxProject, they must have about the least informative website I have ever seen. Going into this knowing that it was drivers for sound cards I managed to glean almost no additional information from their site. Partly this is my fault because I am not as educated on the subject as I could be; partly this is their ridiculous website.
    For my three zone setup, can I run two sound cards, one of which splits for two (two channels each) signals if I use these KxProject drivers (or any others)?
    There website seems to be more focused on self promotion than actual information.
    Nov 2008
    Fargo, ND
    Ah, forget it - I am just going to get three cards.
    Jan 2008
    i assume you know a little about audio processing programs like audio mulch, or console?
    that is essentially what the kx project is, except instead of relying on the pc hardware to do all the processing, the kxproject driver re-uses the audio chips on the soundcard.
    open mobile makes it easy enough that as long as your soundcard shows up with multiple outputs in windows, you should be able to use just the one card..
    May 2008
    Hungary
    its simplier than it looks for the first time
    EMU10K1/2 chipset based card's drivers from creative are very dumb, focuset on playing only. but these chipsets are much more smart than a simple AC97 or other: they have DSP calculation algorithms, for example they are able to calculate lowpass / highpass filters by hardware and several other. here are the DSP editot table from kx driver:
    FXBusX on the left side is the source, epilog on the right is the output. each input soure and output port has a pin on its module (analog, spdif, ac97 and i2s on aud_ext connector, etc). for example, if You connect directly the first 2 pin of FXBusX and epilog, then You get a simple stereo soundcard with analog output, without any DSP processing. but its a very good game to test the modules
    but there is a huge negative score for these creative cards: i tested it with a Live and Audigy1 too, and i had horrible booms on my speakers during turning ON and OFF, despite of that i had used the delayed ON/OFF feature of M4-ATX. now i swapped the creative card to an ASUS Xonar DG: the sound quality is better, and absolutely there is no noise during turning ON and OFF the whole system...
    Jan 2008
    ^what he said..
    the first time i started delving into audio processing, none of it made sense-- it wasn't until i got the sound card, and located a step-by-step demo setup(i believe there is a link on the kxproject page to it) that i finally understood how everything works together..
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Front Panel MB Audio to TRS Connector Solution Wanted
    By cockie55 in forum General Hardware Discussion
    Last Post: 11-11-2009, 04:27 PM
  3. MII-12000 multiple audio outputs/destinations
    By dusthead in forum Car Audio
    Last Post: 11-21-2007, 08:31 AM
  4. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  5. Multiple audio in - potential problems
    By 4.9 EF Futura in forum Car Audio
    Last Post: 06-18-2004, 02:32 PM
