Results 1 to 6 of 6
Thread: Creative Soundblaster XFi 5+1 USB card problem
    Jan 2011
    bursa TURKEY
    Hello everyone
    I have a car pc system used Acer Aspire 3050 as the main unit and a usb touch screen. I use an external car amplificator, a mid component and a sub woofer attached to the unit.
    Inorder to obtain better sound quality yesterday I purchased new usb Creative soundblaster Xfi 5+1. Everything works fine and sound quality is increadibly better now. However I have a problem.
    My problem occures during start up. When the ignition is on my amlificator automatically works. And when I start up the computer manually there is disturbing ecplosion noise several times untill the windows xp loaded. There wasn't such problem with the onboard device.
    How can I solve it.
    Jan 2008
    get rid of the x-fi. this is a known problem and the reason i don't recommend it..
    Jan 2011
    bursa TURKEY
    Actually I can not get rid of it becasue it is the only solution with my laptop. Special car pc devices are not quite common around here so I need to find a sollution.
    The only sollution is to turn on the amplificator after the XP loaded but how? Maybe it is possible to use a relay working with 5v on usb. Or a usb relay control card. Or any other way to turn the amplificator on right after the XP loaded?
    How do you turn on your amplificators?
    Dec 2010
    There are so many threads dealing with this issue dating back several years.
    I feel your pain, and for that got rid of the Creative X-Fi USB. A pulse timer/delay timer from DEI would work or the PAC-TR7. You could go Optical, etc.
    I think you need to research and see what would be best for you depending on what P/S you have and your environment.
    Quote Originally Posted by thewishmaster View Post
    Jan 2008
    ^what he said. there are multiple way to deal with this..(ampctrl, dei pulse timer, and antithump, to name a few..)
    Jan 2011
    bursa TURKEY
    Thank you very much for your helps. I have got a device called, deck converter with amp trigger. It is connected to high level output of sound cards and it converts the signal suitiable for car amp. Also it trigers the amp with the sound signal. This weekend I am going to try the device and share the results.
  1. HFP for Linux Bluetooth Hands Free
    By samr7 in forum Linux
    Last Post: 04-25-2012, 06:45 AM
  2. Creative Sound Blaster X-Fi Surround 5.1 External USB sound card
    By shatteredzman in forum The Review Palace
    Last Post: 09-06-2010, 11:02 PM
  3. Replies: 9
    Last Post: 03-24-2009, 03:23 PM
  4. Graphic card and USB delema!!!!!!!!!!!
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-10-2008, 12:27 AM
  5. The "Official" low profile card post
    By lakorai in forum General Hardware Discussion
    Last Post: 05-22-2005, 09:49 PM
