Results 1 to 6 of 6
Thread: Which Soundcard for this setup?
    Aug 2010
    Hello,
    I have browsed and searched other threads and viewed the FAQ but am still not quite satisfied.
    I have two amps and need to know what sound-card I should be looking for.
    I don't have any rear speakers in my car.
    I have a sub with a built in amp.
    I have an amp powering my front speaker.
    Therefore I need RCA from the PC to the sub.
    Therefore I need RCA from the PC to the amp which powers my front speakers.
    What sort or outputs / specifications should I be looking for?
    Thanks,
    Jack.
    Jul 2007
    Seattle, Washington
    Any 5.1 sound card should do. Then use 3.5mm to RCA to connect to your amps. That's what I did. Hope this helps!
    http://www.newegg.com/Product/Produc...-006-_-Product
    Aug 2010
    Okay so would this soundcard be suitable?
    http://www.ebuyer.com/product/246650
    And which outlet would go to general speakers and which to sub?
    Just want to be sure! =]
    Thanks,
    Jack.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    The documentation would tell you which jack is for which connection. Sometimes the jacks are configurable but you'll need to check unless someone else chimes in on this specific card and knows for sure.
    The specs do say 3 output jacks including a front & sub so you should be good to go!
    Aug 2010
    Ok thanks for your help everyone!
    Thanks again,
    Jack.
    Jan 2011
    jack this is not a problem, you must use a 5.1 sound card of any company and solve your problem as quick as possible.
    hope u might be understand what i told u.
  1. Replies: 6
    Last Post: 04-15-2008, 04:22 PM
  2. FS: Selling my complete CarPc setup for $250
    By remarque in forum Classified Archive
    Last Post: 11-06-2006, 04:50 PM
  3. Ok setup? What Power supply?
    By untal3nted1 in forum General Hardware Discussion
    Last Post: 01-01-2005, 07:17 PM
  4. Carputer setup critique?
    By carterparks in forum General Hardware Discussion
    Last Post: 12-30-2004, 12:08 PM
