Results 1 to 5 of 5
Thread: Another Audio Question!
    Aug 2010
    Okay,
    Getting closer and closer to completing my project, while removing my dash today, it crossed my mind that I could and now want to keep my headunit, but will have to move it to the glove box.
    So within my car there will be TWO audio outputs, the carputer and my headunit.
    How can I have it setup so that I have sound from my computer going to my two amps, and sound from my headunit going to my two amps as well?
    Obviously I will only be listening to one at a time, but don't want to have to swap wires around every time I change device.
    Any help will be appreciated,
    Thanks,
    Jack.
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Your head unit might have an auxillary input; you could run the output from your carPC to your head unit, and use th eoutputs from your head unit to the amp; a bonus is that you can control the sound level with your head unit now, as well.
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    Aug 2010
    When you say auxiliary input do you just me standard 3.5mm audio jack? Which is commonly used to play music via mp3 players etc?
    Thanks,
    Jack.
    Sep 2005
    Bellevue, NE
    Well, that might be it, or it might have left and right rca jacks, which is what mine does. Either one works.
    Core Duo CarPC
    CarDomain page
    Jan 2008
    or you can use rca y-adapters on the amps, or put a fancy switch(at least a double pole, double throw[dpdt]) to switch between them.
    i also have a secondary input(learned i needed it after some hdd problems)-- just a 3.5mm jack in the center console that is connected using y-adapter cables. the only thing is that i can't run the pc and ipod at the same time-- the pc makes the 3.5mm input super low volume..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  1. Audio Question Turtle Beach Roadie
    By 92jdmx in forum Car Audio
    Last Post: 01-05-2007, 07:15 AM
  2. Question about my audio setup
    By djSALIX in forum Newbie
    Last Post: 11-28-2006, 06:37 PM
  3. Laptop Audio Question
    By InVisioned in forum Newbie
    Last Post: 09-25-2006, 01:39 PM
  4. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 03:06 PM
  5. PAC Audio Aux input amp pop question
    By knubile in forum Car Audio
    Last Post: 05-03-2005, 07:28 AM
