Results 1 to 2 of 2
Thread: Help with XM Direct
    May 2007
    Wichita, KS
    Help with XM Direct
    Recently my XMD1000 stopped worked. It happened after re-arranging some parts in the car, but i can't remember anything in particular that would have damaged it.. anyway, here it is:
    I've been using Centrafuse with my XM mostly without problems for at least a year. Now, when i try to use XM, it will do a refresh, but none of the stations will actually play, nor will any of the stations display what is playing. So, it is being seen, but something fails after initialization.
    Using the XMID tool, it will connect and display a RadioID. However, it will stick at "updating stations" and will never display any. With the debug screen it seems to respond ("FROM XM: ..."), but again, never actually plays any stations nor creates a station list.
    I've tried on two separate computers now and two different antennas with the same result.
    The voltage regulator that's screwed into the case does seem to get really hot... hotter than i remember it being, but I can't be sure.
    I can get the debug info from the XMID tool if anyone can use it.
    Anyone have any ideas?
    MySQL Error
    Oct 2004
    yes... the voltage regulator does get hot...
    sounds like the module has failed...
    its prob not getting a sat signal decoded...
    course my 1st thought is antenna, and not getting signal...
    but u might be beyond that
    i havent looked at xm protocol in many years now...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 05:42 PM
  2. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
  3. Possible to split XM Direct cable to computer and XM commander?
    By Jemmi in forum General Hardware Discussion
    Last Post: 12-14-2005, 02:07 PM
  4. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 02:18 PM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
