Results 1 to 7 of 7
Thread: DTA45 Internal Amplifier - current?
    riv
    riv is offline
    Dec 2009
    Anyone has idea how much current it will draw from 12V line? I tried to measure with multimeter during it pay loud music, connected to 2 set of dual 70W/6Ohm speakers (something which I have close by and can use for testing purpose) at maximum volume (right before this little amp shuts down itself) and was getting less then 1 amp on the power line? Am I doing something wrong?
    Raw Wave
    Nov 2009
    Presumably NOT using the right speakers.
    Measuring for the wrong speakers is pointless.
    What RMS power output is it?
    Divide that by 10 for approx (max) current.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    You cannot just divide the output power by 10. Different types of amps have different efficiency ratings, meaning some power going in is wasted as heat.
    You also cannot measure maximum current using a pair of speakers that have a varying load dependent on frequency, and also using music as your signal.
    Are you trying to conduct a science experiment or did you just want to know? The manual states 3.5A with a 12V supply.
    riv
    riv is offline
    Dec 2009
    That's where I confused. I ran very loud music, at maximum volume, connected fairly large speakers... and never got even 1amp on 12V bus.
    Anyway their output sounds like is not great for OEM Nissan speakers, so I thinking if I lower input audio with resistors and connect trough large amplifier, so I use them as pre-amp... would this work?
    Sep 2006
    You want to use the DTA45 as a preamp or line driver into a larger amplifier?
    So, computer -> DTA45 -> larger amp -> Nissan OEM speakers?
    Why do you need the preamp?
    riv
    riv is offline
    Dec 2009
    yes, this was an original plan... until I read about line drivers, as I have both units (for 4 speakers) and don't want to waste another $70, I would like to see if this is going to be possible.
    I am learning during the install, so this is my problem
    Raw Wave
    Nov 2009
    Quote Originally Posted by durwood View Post
    Hence the APPROX and 10 - a common approximation assuming efficiencies of 70%-80%.
    It is merely a guideline, but I find it beneficial knowing a 100W output amp will generally consume approx 10A at 12V-14.4V.
    Conversely, at 3.5A in, I'd assume 35W output. (Unless the 3.5A is a peak etc.)
    I'll leave impedance to the impedance matchers. (I misread the original impedance as being tenfold - ie, 60 or 70 Ohms! )
  1. Boss ch700 amp question
    By Jensen12345 in forum Car Audio
    Last Post: 08-10-2010, 07:29 PM
  2. Replies: 231
    Last Post: 10-26-2007, 05:41 PM
  3. Amps, watts, volts and ohms
    By dagnasty in forum The FAQ Emporium
    Last Post: 12-30-2005, 12:35 PM
  4. Current through a relay between two batteries
    By RFMan in forum Power Supplies
    Last Post: 07-25-2005, 03:13 PM
  5. SoudBlaster PCI128 Do I need amplifier
    By Eddy25 in forum General Hardware Discussion
    Last Post: 10-07-2002, 10:57 PM
