I got the Intel BOX DG45FC and I'm finding it impossible to separate the channels.
When I use the HD audio or the control panel levels and speaker testing... sound comes out of every speaker all the time.
Does anyone else have this board. I've tried different drivers, different programs... nothing. I did a search online and found people having similar issues with this board, but haven't found any solutions.
I might just go with usb audio via creative. I guess I just want to know whether I should ever recommend this board or not. This board is supposed to be great for building a home entertainment system... but I can't see how thats possible if the on-board 7.1 is more like 1.0.
Its definitely set to 5.1 in the software and the ports are programmed correctly.
But thats mute. I've set it to stereo and still you here R/L together.
Well how is your cables ran from the computer to the amp then to the speakers?
For example this is my setup
I use a 5 channel amp http://www.sonicelectronix.com/pictu...cture_id=62924
Using 3.5mm Mini Plug to RCA cables which splits your L (white cable) audio and R (red cable) audio
Green sound port goes to Ch 1 (L white) Front Left and Ch 2 (R red) Front Right
Blue sound port goes to Ch 3 (L white) Back Left and Ch 4 (R red) Back Right
Red sound port goes to Ch 5 (L white) Sub and [Ch 5 (R red) not plugged in because I have no center speaker(center audio is played through front L/R in xp it was auto and in win7 realtek drivers had to specify this or I would never hear center channel sound]
Then I use the built in xover for chan 5 to only get low sound for the sub.
They cables are fine. I took everything out except the front audio in the green plug,.. made sure they're set to front R/L. Its a stereo 3.5mm to rca, the rca's are plugged into my amp... I got that.
Sound come out both no matter what i do with software or hardware. I'm about to throw this board away.
Its something software related. Centrafuse crashes when jumping from one audio source to another. I have mp3's (source - harddrive), XM radio (source - iPhone, input - on board audio blue), Boomzbox (source - usb,.. always has cracking sounds in the 16K freq - I can just go to the eq and turn it all the way down but then i don't here the high hat or tweets so what's the point of hd radio).
