Results 11 to 20 of 24
Thread: Help! High pitch ringing noise!
  1. #11
    Jan 2008
    i was hoping you guys would search -- there is tons of info on GL's, and how to fix them.
    nivanov is correct on grounding the motherboard-- many times the motherboard is correctly grounded through the 20/24 pin connector, so physically grounding the motherboard could cause multiple ground paths-- which is a good definition for what ground loops are..
    i have occasionally read of certain onboard sound cards not sharing the same ground plane as the rest of the board--where the designers expected the metal pc case to be used as the connection, so motherboard grounding would be required in this case.. but the creative x-fi you have 'should' use the shield of the usb cable for a common ground..
    many times GL's are caused by poor/dirty/incorrect connections. this could be on either the power or ground side, but the ground connection is the one that will cause the most amount of problems because it is the one that everyone neglects the most..
    where did you attach your pc ground? did you sand the paint off? are there any other devices that share that same ground?
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  2. #12
    Constant Bitrate knownchild's Avatar
    Dec 2010
    IOWA
    Idea
    I used a 10 gauge wire for my 12v line and a 14 gauge wire for the ground, could this cause a ground loop? or not a good ground?
    Never accept STOCK equipment.
  3. #13
    Jan 2008
    that is a good start. your ground should always be at least the same gauge, or larger then the positive power wire. and did you sand the paint off the ground connection point?
    HID retro--100%
  4. #14
    Dec 2010
    IOWA
    sure did
  5. #15
    Jan 2008
    ok, sometimes when you share a ground with some factory devices, it can cause a GL, or if your amp has a different ground point then your carpc, that can also cause a GL.
    HID retro--100%
  6. #16
    Dec 2010
    IOWA
    Yes
    I read up on the whole ground loops and what can cause them. I have my carputer which is grounded to the front passenger side of my car frame, my head unit (i use this as an amp for now) and my Viper remote start which is grounded on the drivers side part of the cars frame.
    Im sure all three of these device being grounded in different areas may be causing the ground loop, thing is if all devices are properly grounded and i isolate the device(s) which is causing the loop will grounding it in a different area of the vehicle make a difference? or should i make them all have the same ground?
  7. #17
    Jan 2008
    non-audio devices can sometimes affect audio devices, and cause a ground loop when connected to the same point.
    to prevent that, just try connecting the radio, and carpc ground together.
    HID retro--100%
  8. #18
    Dec 2010
    IOWA
    So can i drill a hole right next to the PC's ground instead of using the same hole? without it creating a loop?
  9. #19
    Jan 2008
    sometimes.. and sometimes not..
    it would be better to use the same bolt if possible.
    HID retro--100%
  10. #20
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    There are a lot of things to consider when it comes to getting rid of induced noise. Location of the equipment, proximity to power wires and equipment, and poor grounds are just a few of them. I eliminated 95% of the noise I got by moving my amp and computer from the shelf above my gas tank in the trunk (right above a very noisy fuel pump) to an amp rack I built and put in the base of the trunk, and by using a distribution block for all of the equipment grounds that connects to a good chasis ground by a 4GA wire (I already had a power distribution block for the equipment). The rest was eliminated by grounding the RCA cables at my USB DAC to the same ground distribution block.
    Moving the computer to a different location, using a different ground, and grounding the RCA cables at the computer are things you can try.
  1. need help high pitch humming noise :/
    By cla1067 in forum Car Audio
    Last Post: 01-06-2011, 01:39 PM
  2. 66 Mustang - High Pitch Noise / Feedback
    By raggedrebel92 in forum Newbie
    Last Post: 09-18-2010, 09:35 PM
  3. High pitch noice
    By Charles1 in forum Car Audio
    Last Post: 07-26-2006, 11:06 PM
  4. high pitch sound
    By nguyenpd in forum Car Audio
    Last Post: 06-28-2006, 08:21 AM
  5. high pitch coming from TFT LCD
    By r2o4b0sx in forum LCD/Display
    Last Post: 09-16-2003, 04:10 PM
