Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Amp 9 it's a good amp for a DD?
  1. #11
    Jan 2008
    it 'should' do with the way the amps are designed.
    i am by no means a expert on any of this(just a guy with a internet connection )
    from the statements made by both amps--from either their spec sheet, or the online store, i am lead to believe that the Sure series of amps are designed for small projects where the amps would stay permanently installed, in a non-mobile environment.
    comparing both the 4x100, and the amp9, there are visible power filtering devices on the amp 9, that are not present on the Sure 4x100:
    the amp9 has some large storage capacitors--these both provide a level of incoming power filtering, and some reserve power for the amp chipset(only a little as capacitors can discharge their entire storage capacity very fast, but if the draw is small, it can take a while to discharge..).
    the amp9 also has some visible coils-- these are mostly low-freq power filters but power filtering none-the-less..
    the Sure 4x100 has some visible coils near the input stages, but no visible storage capacitors like other amp designs..
    after briefly looking at other amps in the Sure series, there are some very small supply capacitors on many of the designs, but nothing like any other amp design i have seen-- most amp designs will have larger capacitors similar to the amp9-- because it allows for more power-- both for filtering, and for storage..
    so after my non-expert look at both designs, i would have to say that all the sure-series amps will require voltage, and power regulation in a car environment, because none of them appear to have sufficient filtering built in..
    this is probably the biggest reason that they are so much cheaper then the amp 9, or other similar tripath-based amps that cost more..
  2. #12
    Newbie elBradford's Avatar
    Mar 2008
    Utah
    Quote Originally Posted by soundman98 View Post
    Thanks for your input, makes sense.
    monkey stole my pen
    My Worklog
  3. #13
    Mar 2008
    Utah
    I still think I'm going to pick up one of the Sure amps and try it out. These seem to run OK on 12V according to this forum: http://www.diyaudio.com/forums/class...tp2050-15.html
    Worst case, I can't use it in the car. Best case, it rocks and power filtering isn't an issue at all.
    monkey stole my pen
    My Worklog
  4. #14
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    very glad to hear you're going to try it out. that is what this community thrives on. Im pretty sure you wont be wasting money,
    are you going to control the volume from your pc or from one of these boards:
    http://www.parts-express.com/pe/show...number=320-318
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  5. #15
    Mar 2008
    Utah
    I hadn't seen that, I was planning on using this clarion preamp/eq which has good reviews: http://www.amazon.com/Clarion-EQS746.../ref=de_a_smtd The Sure amp says not to use a preamp, however in one if their review videos (for the Sure) they simply hook an ipod up to it. The voltage output for this preamp/eq isn't much more than the voltage output of an ipod so I think it will work.
    monkey stole my pen
    My Worklog
  6. #16
    Mar 2008
    I am also going to try the clarion eq. i won't have a headunit anyore, so can i just use the power/ground from stock headunit's harness?
  7. #17
    Jan 2008
    for powering only the clarion eq, the factory power wires should be fine.
  1. Replies: 0
    Last Post: 09-01-2009, 08:42 AM
  2. Replies: 13
    Last Post: 10-14-2006, 11:12 AM
  3. Volfenhag amplifier, good? No good?
    By drewbad in forum Car Audio
    Last Post: 07-28-2006, 05:10 PM
  4. Is this a good price and good quality?
    By donchoya in forum Newbie
    Last Post: 02-10-2004, 07:24 PM
  5. GOOD LCD's to use with GOOD Vid Out cards?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 07-10-2000, 05:42 PM
