Results 1 to 10 of 17
Thread: Amp 9 it's a good amp for a DD?
    Constant Bitrate tibimakai's Avatar
    Feb 2005
    San Pedro, USA
    I'm building a DD PC and I would like to get some feedback from owners of this amp 9(basic mostly) before I order it.
    it heats up a lot? it needs a big heatsink?(pictures would not hurt) anti thump feature works well?
    there is another alternative out there? it has to fit in a DD case.
    I don't need crazy power, just like a car stereo or a bit better.
    Jan 2008
    this is about the only documented amp 9 dd install i know of...
    http://www.mp3car.com/worklogs/14566...n-project.html
    Feb 2005
    San Pedro, USA
    thank you. I have folowed that thread, but I don't see a review or any real info about it.
    I don't remember the names but I remember that who makes those DD cases, made a pc to sombody with a motorhome and they couldn't figure out some noise issues and he was selling the amp. I have the same Intel Atom 230 board as him.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you'll have to double check the size, but these get decent ratings:
    http://www.parts-express.com/wizards...ge+Flash+Panel
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Newbie elBradford's Avatar
    Mar 2008
    Utah
    Quote Originally Posted by scott_fx View Post
    That 4x100 Sure amp looks like it will be perfect for a project I'm throwing together (and maybe start selling as well) - does that look like it would put out good, clean power for a head unit replacement? Would 12V from the car battery be adequate to power it?
    monkey stole my pen
    My Worklog
    Feb 2005
    San Pedro, USA
    I knew about that amp and asked on the forum about it and did not get an answer that I have expected and decided not to go with it.
    I have ordered today the Amp9.
    Jan 2008
    those parts-express amps use variations of the same tripath chipset that the amp9, and the bybyte amp are based on, so sound quality should be just as good.
    but the power supply specs say they will take dc voltage from 10-30v, but it is a little sketchy on weather dc input voltage affects overall output--like normal car audio amps, or weather the output power ratings were done at 30v power input..
    Mar 2008
    Utah
    Quote Originally Posted by soundman98 View Post
    The Amp9 at 75 euros is quite a bit more than the bybyte and sure amps and if the performance is the same not worth it imo. All I need is one of these and a eq/pre-amp and a source and I should be good to do. Any tricks on eliminating pops when it's powered on?
    Edit: This pdf for the sure 4x100 amp states that it has pop protection built in, but that it shouldn't be used in conjunction with a preamp or with an unstable power supply - I'm guessing directly hooking up to the 11-14 volts of a car battery would be considered unstable?
    monkey stole my pen
    My Worklog
    Jan 2008
    yes. so you would need a dc-dc power supply capable of delivering 12A max current to correctly supply the amp (it starting to get more expensive )
    Mar 2008
    Utah
    Except the Sure 4x100 will accept 6v-30v... In the thread about the Amp9 it appears that guy wired it up directly to the BAT line. It seems like hooking up this Sure amp to a relay controlled by ACC to the BAT line with an inline fuse should work but I'd really like to know if it wouldn't and why. Thanks soundman.
    monkey stole my pen
    My Worklog
  1. Replies: 0
    Last Post: 09-01-2009, 08:42 AM
  2. Replies: 13
    Last Post: 10-14-2006, 11:12 AM
  3. Volfenhag amplifier, good? No good?
    By drewbad in forum Car Audio
    Last Post: 07-28-2006, 05:10 PM
  4. Is this a good price and good quality?
    By donchoya in forum Newbie
    Last Post: 02-10-2004, 07:24 PM
  5. GOOD LCD's to use with GOOD Vid Out cards?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 07-10-2000, 05:42 PM
