Results 1 to 7 of 7
Thread: hooking up speakers with no head unit, using pc
    Mar 2011
    Tucson
    i've been looking into the carputer and getting stuck on how to hook up the speakers to it. I would be replacing the head unit with the monitor and looking to run centrafuse. i would like to keep control of balance and fade if possible. any suggestions? on top of that here is how my oem system is hooked up:
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    You need an amplifier. There's no way to connect your car's speakers directly the computer.
    Jan 2008
    getting balance is easy-- windows usually includes that in the sound settings-- though i can't seem to find it on my win7 laptop..
    fade-- i have not seen any reliable solutions to get this to work.. though there are work-arounds using specific external eq's.
    Nov 2010
    Panama City Beach
    Buy a good quality amplifier, like a JL Audio, and you will have an accessory cable that you install in the front so you can keep control over the audio levels for each channel.
    Mar 2011
    Tucson
    would it be possible to take apart the head unit and use the amp from it and rewire the input to be the computer rather than the fm or cd?
    Mar 2011
    Durban, South Africa
    Hi Chris. You don't really want to start doing that. As kegobeer suggested an amp would be the best solution. However you could probly use an FM Modulator or one of those tapes (not sure what they called) to connect your pc up to your existing head unit. Would probably be the quickest and cheapest way, but not the best.
    Jan 2008
    Quote Originally Posted by youngchris03 View Post
    with enough time and dedication anything is possible.. i just don't think it is worthwhile..
  1. Hooking a computer up to your head unit via USB???
    By UnusuallyGenius in forum Car Audio
    Last Post: 10-17-2009, 04:11 AM
  2. hooking up system with stock head unit
    By kxracer411 in forum Newbie
    Last Post: 07-22-2008, 01:17 PM
  3. Help..hooking up new head unit to monsoon amp
    By jstick81 in forum Car Audio
    Last Post: 04-23-2008, 05:21 PM
  4. Need help hooking up mp3 to car head unit
    By lousvette85 in forum Car Audio
    Last Post: 11-17-2005, 09:13 PM
  5. Hooking up to my head unit/ speakers
    By ofthedove in forum Newbie
    Last Post: 10-07-2003, 04:46 AM
