Results 1 to 3 of 3
Thread: Tower PC to stereo audio options
    Mar 2011
    Exclamation Tower PC to stereo audio options
    Trying to hook up Windows 7 machine with PCI 5.1 sound card to new ALpine head unit with optional aux RCA input cable. No dice with trying to use 3.5mm to RCA adapter plug for audio output from PC. Get nothing on Aux input on stereo this way.Tried hooking straight to zx1500:1 Kicker amp and 350:4 Kicker amp and just get extremely loud buzzing with no sound from PC going through system. Sound card does have an optical out but not sure if there is a device to convert this to RCA or not. This is for a party bus application so sound quality is fairly important. Didn't want to go to FM modulation if at all possible. Please help!!
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    Maybe this will help. It's a toslink/coax digital to analog converter.
    http://www.google.com/products/catal...d=0CDgQ8gIwAg#
    You may want to check the cable and/or the y-splitter/adapter you are using to connect the sound card to the amplifier.
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Use the green plug on the PC. If there is no sound coming out of that port then it could be many things.
    1) Are the soundcard drivers installed?
    2) Is the sound muted?
    3) Is the soundcard selected as the default card?
    4) Is optical out selected instead on analog as the default?
    I wouldn't bother with optical out unless your headunit accepts this type of signal.
    Once you have sound and there is still buzzing, are you using a power inverter instead of a DC-DC power supply?
  1. Audio options other than HU?
    By elimenohpee in forum General Hardware Discussion
    Last Post: 07-27-2007, 09:36 AM
  2. HArdware options to preserve OEM stereo functions...
    By emsjeep in forum General Hardware Discussion
    Last Post: 01-24-2007, 01:16 AM
  3. Audio input Options
    By eazyrog in forum Car Audio
    Last Post: 07-13-2005, 02:36 AM
  4. Options for 300ZX Audio
    By SFiorito in forum Car Audio
    Last Post: 07-25-2004, 11:37 PM
  5. Any options for car audio?
    By nibix in forum Car Audio
    Last Post: 07-03-2004, 02:47 PM
