Results 1 to 10 of 15
Thread: carputer on board soundcard
    Dec 2010
    Hi eceryone, I did a little searching before posting this but couldnt find the answer. i just finished building a carpc and am using the intel atom D525MW motherboard with onboard sound card. this is installed in my 99 mercedes with factory bose amp. i used an PAC OEM 2 in reverse maner in order to have RCA plug ins to the speaker wires. everything works great except my base and volume are very low! so i was trying to find a solution for this and came up with a few things.
    1. run a headunit which i dont have the room for so out of the question.
    2. run an amp right out of the car pc into the pac oem 2 and then into the factory amp. i looked into a few cheapy amps because space is an issue for me and found a couple that are 300watts 4 channel. but is a 300 wat 4 chanel enough?
    3. run a soundcard which i heard of the name sound blaster. i'm not sure about this option can someone elaborate on this a little more.
    keep in mind im running factory speakers so i'm not looking for anything crazy just factory sound quality. Thank you very much in advanced.
    3.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    im confused on your wiring. i think what you're doing is taking your soundcard as if it's a speaker level output, inputing it into the pac oem2 and getting line level output... hooking that up to the amp? if that is the case then the pac oem2 isn't needed. your soundcard outputs line level so you should be able to just wire that directly to the amp.... but it's bose.... hmmm something isnt adding up
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Scott is right, you shouldn't need to use a LOC at all. By using the LOC, you are reducing the signal voltage going into the factory amp because they are designed to take a high level signal and attenuate it to a low level signal that amp can take in. The computer soundcard is considered a low level signal, and the amp takes in a low level signal. make sense?
    Low Bitrate cmcd2820's Avatar
    May 2010
    Roswell, New Mexico, United States
    I concur with durwood. 3.5mm jack to RCA cable to the factory amp. Your Line Output Converter (LOC) is doing exactly what it is designed to do, but you don't need it.
    Dec 2010
    Thank you very much too all the friends for your responces, that makes perfect sense. I think this is what i am going to do. eliminate the pac oem 2 and plug in the rca,s coming out of the car pc into a 300wat 4 chanel mini amp and then connect that amp to the bose amp via the factory wiring and i think i will have myself a winner. here is the last question:
    is the 300 wat 4 chanel amp enough? and is there a super small amp that you guys recomend?
    Dec 2004
    Los Angeles Ca
    you dont need the extra amp. you go from your soundcard into the bose amp.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2010
    areyousure, because this is my factory bose amp not a high powered aftermarket amp. while i had mt stereo out of my car i was using my ipod to listen to music and i had it hookedup to the bose amp directly without the pac oem 2 and the volume and base very super low, but i'm not sure fi that would be the case with the car pc as well i dont know if the onboard sound card is much stronger than the ipod or not.
    Dec 2004
    Los Angeles Ca
    what you're describing to do is go in a circle. if anything; possibly you need an inexpensive line driver.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2010
    whats a line driver?
    Dec 2004
    Los Angeles Ca
    think of it as an amplifier for you rca's
    ---------- Post added at 09:40 AM ---------- Previous post was at 09:39 AM ----------
    http://www.google.com/products/catal...d=0CFkQ8wIwAQ#
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. other soundcard options or board
    By customaudioman in forum High End Solutions
    Last Post: 09-06-2009, 01:25 PM
  2. Replies: 5
    Last Post: 11-30-2007, 10:58 AM
  3. Best Soundcard for a Carputer?!
    By stonep in forum General MP3Car Discussion
    Last Post: 07-25-2005, 08:31 PM
  4. Distortion from my carputer soundcard?
    By sushi1111 in forum General Hardware Discussion
    Last Post: 03-23-2005, 08:13 AM
  5. How is this mother board carputer or not??
    By radioman193 in forum General Hardware Discussion
    Last Post: 08-14-2001, 07:14 AM
