Results 1 to 8 of 8
Thread: Where to install my amp
    Oct 2010
    Perth, Western Australia
    Hi All,
    Today I started to install my amp for my carpc in my Toyota Corolla 02, I've run 8 guage, the remote line (16G) to the boot, under the doors, also the RCA Cables.
    G
    Its only a small 2 Channel Amp ( Fusion 350 watt), but will do what i need.
    But now not sure where to mount the Amp, so posting on here.
    Should I.
    Continue with the Boot install:
    Back of Rear Seats (Not sure of what i can attach it too here and they fold down so not keen on this)
    Fix to floor of Boot
    Make an MDF box, Mounting Face
    Move to under Drivers seat
    Reluctant to put it under the passenger seat as right below ive notice a bunch of cables/pipes, havent checked what they were but just stearing clear.
    Ideas?
    Regards
    Rapture
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I did an install on a 03 Jetta with folding back seat. I installed two decent size Alpine amps upside down to the bottom of the package tray. That was over a year ago, no issues, he is very happy with the install.
    Oct 2010
    Thanks PhiG,
    There is some room near the spare if i remove some plastic storage areas, considering that at the moment,
    The problem i have is im always dropping the back seats to put large items in there after expensive trips to Bunnings (Australian Hardware Store), i think i could do with a truck like yours.
    Jan 2008
    for space-constained installs, the spare tire area like what you were thinking is a common spot. also look at the sides behind the rear tire 'hump'(wheel well), or sometimes people have mounted the amps upside-down on the underside's of the rear parcel tray.
    Oct 2010
    Installed the Amp on the side panel, drilled 4*2 sets of holes and fed cable ties through and secured it that way, i couldnt use screws without putting them into the body, but it is all holding up well.
    Photo to follow as it got dark.
    Feb 2007
    PA
    Do it like this!
    Custom made from http://www.jsenclosures.com/
    Oct 2010
    Quote Originally Posted by soundman98 View Post
    Thanks soundman98, the side is where it is at the moment, will see how it goes.
    darroj thanks for the pic, your install looks like the back seats, i own a hatchback and alway dropping seats for building/gardening stuff, so not practical.
    Feb 2007
    PA
    RaptureOz - ah ok, he also makes some nice underfloor ones if you're interested... here's a sample on a subaru station wagon (so the rear seats can fold down all the time too!) but I realize that may not help much with the amp, but it helps with the sub...
    http://www.jsenclosures.com/product_...products_id=26
  1. 01 Holden COmmodore Install - First Install
    By trigge in forum Show off your project
    Last Post: 02-02-2009, 03:02 AM
  2. 2007 Mustang Install (first car pc install)
    By Hessian in forum Newbie
    Last Post: 06-28-2007, 08:44 PM
  3. XP install hold on install because of space
    By sammie1303 in forum WinNT Based
    Last Post: 11-16-2006, 12:09 PM
  4. Car PC install newb install question....
    By SciFiFan in forum Newbie
    Last Post: 07-28-2006, 06:33 AM
  5. Replies: 12
    Last Post: 08-30-2005, 09:16 AM
