Results 1 to 3 of 3
Thread: 300w Amp Engine interference
    Feb 2011
    Good afternoon,
    When trying to run audio through the amp and video on the VM70 touch screen there is a terrible interference that is worsened when i turn the engine on, This only happens when both amp and screen are on together, seperatley they work fine, im not sure wether this is a grounding issue as as ive said they work perfectly sepereatley in the car.
    im half expecting someone to say just use one at a time
    any help would be apprecaited. excuse me if im beign dumb.
    Raw Wave
    Nov 2009
    I'd start with the grounding.
    Jan 2008
    Quote Originally Posted by OldSpark View Post
    +1
    to expand a bit on the idea-- many times a poorly connected ground--either a dirty connection, or loose connection, or multiple grounding points for multiple pieces can cause the problems your describing. they are very common in car audio installs. i suggest you search a little for 'Ground Loop'. there is tons of info on what can cause them, and how to fix them around here..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  1. 300w Amp and Touch screen interference.
    By sam1990rhodes in forum Newbie
    Last Post: 03-17-2011, 04:54 PM
  2. weird sound interference only when engine is on!
    By canadamatt in forum Car Audio
    Last Post: 05-02-2007, 11:41 AM
  3. WiFi (engine interference)
    By Shagzter in forum Wireless Communications
    Last Post: 03-20-2007, 12:51 PM
  4. LCD interference from engine.
    By JADiss in forum LCD/Display
    Last Post: 06-03-2004, 05:31 PM
  5. Does a 300w PSU need a 300w inverter?
    By Max018 in forum Power Supplies
    Last Post: 03-24-2004, 11:53 AM
