Results 1 to 3 of 3
Thread: ASIO 4 all on Atom board - basic sound processing only?
    Jun 2008
    Perth, Western Australia
    I have the usual Intel D945GCLF2 motherboard, atom dual 1.6gig.
    I want to pick up a second USB DAC, and have one feeding the mids up front, and the second pushed out to another amp for subwoofers.
    Can the atom board support splitting the signal into 2 frequency bands? I don't want to do timing etc, just basically have it so frequency below x -> DAC 1, frequency above x -> DAC 2.
    Or am I better off just splitting the output of the 1 dac and feeding it to two amps, and having the amps do the crossover work using the frequency controls on the front of them?
    The system currently runs win7, CF3.5, GMPC for nav and TotalMedia 3.5 for DAB+ / DTV viewing (on odd occasions and for testing). I think the cpu sits at about 20% useage in normal situations.
    Jan 2008
    you can definitely try it.. everything has a free demo, so it can't hurt..
    on that same board with 3-way active setup using some poorly coded x-over plugins, and rr, i would get audio drop-out's at almost anything above 30% cpu...
    some recommendations for low cpu utilization-- try it using audiomulch, not console--when i used console, it seems to use more cpu with the same plugins (i only used console on that board because it was all i could afford at the time). the best filter program i have used so far is rubberfilter. it has relatively low cpu use, and a lot of features.
    and instead of using A4A to try to get a ASIO setup, just try to use VAC to get the audio into the program, and stick with the windows drivers-- so the processor doesn't need to work any harder..
    Mar 2011
    TBH I'd just use an external signal processor / eq in-between the carputer and amps. I understand you probably don't want to, but in the end it probably won't be as much more money out of pocket, and it'll be a hell of alot easier to settup.
  1. Laptop sound processing in a HT setup
    By kylebigmac09 in forum Newbie
    Last Post: 01-22-2010, 12:52 PM
  2. Volume control and ASIO sound card in RR
    By rodweb in forum Road Runner
    Last Post: 08-07-2009, 03:43 PM
  3. Sound Processing and X-Meridian
    By qpwoeiruty999 in forum High End Solutions
    Last Post: 01-13-2009, 08:15 AM
  4. Sound processing software
    By yarceo in forum Software & Software Development
    Last Post: 10-16-2003, 08:34 PM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
