Results 1 to 2 of 2
Thread: loud engine noise coming though my car speakers
    Apr 2011
    Angry loud engine noise coming though my car speakers
    I have an aftermarket audio system installed in my car, the system was playing perfect with no engine noise, a few days ago while the music was playing I unscrew one of the 6x9 speaker and it accidently touch the metal panel of the car and sparks, from that moment I am getting very loud engine noise and when I turn on my headlight there is another strange noise, I try to use a ground isolator which helps a little with the engine noise, but whenever I turn on my headlight that noise is still there, I try re-grounding, new RCA leads, make sure that all power wire run on one side of the car, and the RCA leads run on the other side of the car, and still no luck. Can someone advise, thanks
    Feb 2011
    try a ground loop isolator, you can get them on ebay for fairly cheap, solved my issue
  1. Engine Noise in speakers
    By OpIvy in forum Car Audio
    Last Post: 09-25-2008, 12:12 PM
  2. engine noise through speakers
    By HumanMachine in forum Newbie
    Last Post: 09-20-2007, 12:07 AM
  3. Noise coming through speakers - Help Needed
    By tbird2340 in forum Car Audio
    Last Post: 09-27-2004, 04:31 PM
  4. Loud thump on start coming from factory sub
    By wkolodny in forum Car Audio
    Last Post: 05-31-2004, 09:48 PM
  5. Funny noise coming out of speakers...
    By SuperMatty in forum General Hardware Discussion
    Last Post: 03-17-2002, 11:01 AM
