Results 1 to 5 of 5
Thread: Amp for my two subs
    Mar 2011
    Amp for my two subs
    I have two 10in 300 watt Rms and 1200 watt max power subs. I was wondering what amp i shold get that could power thoes subs.
    Not to pricey please!!!
    Jan 2008
    a 600w rms amp.
    Mar 2011
    whats a good brand?
    Raw Wave
    Nov 2009
    I was going to say 900W RMS (2x300 WRMS + 1200/2 WRMS)
    And that handles whatever impedance you connect them as, and limits the power to each as required...
    And assuming the quoted max power is music power = 2x RMS power. If it is any other "max power" rating, then don't overpower them. (IE, 1200W max can be 150W RMS, hence 750 W RMS). But that depends on how you connect them....
    You probably want to separate the different speakers, ie, one output for the 2 identicals, and one for the other.
    Not that I am an audio or amp expert....
    Jan 2008
    i am betting the subs are either lower-end sony, pioneer, or rockford fosgate subs-- so the peak figure is useless. (they could have ran a 1khz sine wave to get that...)
    but honestly, it is all a rule of thumb-- i use to run some 125w rms/ 300w max subs off a 600w max amp(it's a sony, so a assumed 300w rms, though prob. less) and never had a problem..
    heat is what destroys a sub-- and you can run a 100w sub with a 1,000w amp as long as you can get rid of the extra heat that the voice coil generates..
    back to the original question-- what is your budget? a cheap amp to me, and a cheap amp to most are 2 different things..
  1. Replies: 4
    Last Post: 07-23-2008, 08:54 PM
  2. # of subs in car
    By smurfs122 in forum Car Audio
    Last Post: 02-19-2007, 08:51 AM
  3. Looking for help with car pc and subs
    By ecswookie in forum Newbie
    Last Post: 01-09-2006, 05:44 PM
  4. 2 subs in one box, or 2 subs in 2 boxes
    By zzachattack2 in forum Car Audio
    Last Post: 10-19-2005, 01:49 PM
  5. F/S: Amp & Subs
    By 89Excess in forum Car Audio
    Last Post: 04-17-2004, 11:50 PM
