Results 1 to 2 of 2
Thread: Audio Can-Bus Specification !
    May 2010
    Hello Everyone ,
    I want to implement a small Infotainment System for my FIAT (Increase/ Decrease the volume and change Radio station .. and so on).
    I have connected my Laptop to this car to Normal Notebook via PCANUSB CAN-reader and I got the Specification in the File attached .. but I have some doubt since I have done before small can diagnose via OBD-II port and I know that CAN-bus works in query-response mode.
    but here I got in the attached documentation only one address .. Is the audio System works in the same way of OBD-II or I should only set the desired data field and send it to the CAN bus in order to change the CAN value ?
    can you please give me an example which I can see how the data filed could be looks like .. if you don't mind ?
    Thanks in advanced for your support.
    May 2010
    Hey All,
    No body knows what is the answer of my Question .. No suggestions ?
    or I might wrote the topic in @ the wrong forum ?
  1. OBDII Specification/Odometer Read
    By tahrens301 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-01-2012, 06:01 PM
  2. Firmware Update Specification for Devices with STN Bootloader
    By Vitaliy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-28-2011, 06:28 PM
  3. Wire Specification
    By asp_777 in forum Power Supplies
    Last Post: 08-13-2007, 03:59 AM
