Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Small amplifier board reviews for in-dash double DIN PC
  1. #11
    Dec 2007
    Sydney Australia
    Quote Originally Posted by stretch4x4 View Post
    This shop has a range of small amps:
    http://stores.ebay.co.uk/Techex-Onli...=p4634.c0.m322
    I am planning on the same thing but still looking.
    I have a similar amp to the red 500W Car Motorcycle Boat model in this shop.
    I have 2 of them side-by-side in the dash, one for FR+FL and one for RR+RL and you can check them out in my worklog here (third post).
    They don't seem to get warm at all as the whole case is metal and acts as a large heatsink.
    I opened one up and it looks like the same monolithic chip as in the DTA45 35W 2-ch example in the OP.
    Sound is comparable to my high-end OEM headunit and there is no clipping of the heavy bass that I can tell.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  2. #12
    May 2010
    Australia
    I maybe have stolen that link/idea from your posts
  3. #13
    Mar 2011
    Marietta, Ohio
    I have picked up one of the "motorcycle" 4 channel amplifiers for my CarPC install. Specifically the Phonics Digital PD-IC4CH.
    While I have not had time to sufficiently bench test this product here are some specs:
    4 CH Full Crossover (LPF-HPF-FLAT)
    • Sensitivity Input Control
    • Remote Soft Delayed Power On
    • Gold Plated Terminals
    • Power On LED
    * 300W Peak
    * Selectable Crossover: LPF,FULL,HPF
    * 4x30W RMS @ 4 OHM Mono
    I am not sure it meets your size requirements but it is not very large at It's appox 5.5" X 6.5". Can't be much larger than setup pictured by RevheadKev if at all.
    Just bringing to light a motorcycle 4 channel option vs dual two channels.
  1. Any type of small amplifier for phono rca plugs?
    By Cheekz185 in forum Off Topic
    Last Post: 11-09-2007, 03:39 PM
  2. Looking for small amplifier
    By Suprapc in forum Car Audio
    Last Post: 10-05-2005, 05:27 AM
  3. looking for a 5.1 channel SMALL amplifier
    By RogerWilco in forum General Hardware Discussion
    Last Post: 09-21-2004, 03:19 PM
  4. Small Amplifier
    By pbrinich in forum General Hardware Discussion
    Last Post: 02-12-2004, 05:01 PM
  5. Wanted: SBC Board or small ATX board
    By solaraboy in forum Classified Archive
    Last Post: 09-18-2001, 11:44 PM
