Results 1 to 4 of 4
Thread: Weird Amp Problem
    Oct 2010
    Victoria, Australia
    Weird Amp Problem
    Recently got a free amp and subs from a mate of mine because the amp was driving him nuts. He couldn't work out why it would works sometimes and not others. After a fair bit of testing I've worked out how to avoid the problem but not a nice solution of the cause of the problem. Pretty much the amp will go into protect mode if ACC is turned on or the car is started (so pretty much when turning on the amp) while the RCA's are plugged in to the amp and into a HU or iPod at the other end (so if the circuit is completed). So it'll work if i unplug the RCA's from my ipod then turn the car on then plug them in. I have the speakers amp plugged into the ipod and the mono wont work if that one is plugged in either, thinking maybe the other amp is sending some kind of signal down the line? I have opened the amp up and nothing seems blown or broken in any way. Any thoughts?
    Oct 2010
    Victoria, Australia
    No-one has any ideas?
    Jan 2008
    you could probably wire in a delay-- something based off multiple relays connected to a pulse timer(555-based timer circuit). but for the cost of the relay's+pulse timer, you could probably replace the amp...
    Oct 2010
    Victoria, Australia
    I am an electrical engineering student and can get most electrical components free so maybe this is my best option
  1. Weird Mic Problem.. Help!
    By veetid in forum Car Audio
    Last Post: 09-30-2006, 07:05 PM
  2. SP7 VGA...weird problem
    By Carter in forum LCD/Display
    Last Post: 07-15-2006, 02:38 PM
  3. weird RR problem
    By liquid_smoke in forum Road Runner
    Last Post: 12-01-2005, 01:52 PM
  4. Weird Weird Weird Holux 210 problem
    By omernesh in forum GPS
    Last Post: 07-01-2005, 08:55 PM
  5. Weird Problem...
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 02-17-2004, 04:31 PM
