Results 1 to 4 of 4
Thread: Can I mix and match speakers?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I have decided to finish the audio aspect of my install. I figured I need to finish that first since the Car PC is useless with no sound.
    Originally I wanted to put Alpine SPR-17C speakers all the way around. They are 100 RMS speakers. I am now trying to penny pinch and realize I do not want to spend $120.00 per pair on speakers. So I decided to take a look at Alpine SPS-600 speakers, which are 80 RMS. What I want to know, is it ok to still use the pair of SPR-17C speakers and also use the SPS-600 speakers?
    Would the SPR-17C still work to their full potential if the amp is putting out only 80 RMS per speaker? Also where should I use the SPR-17C speakers? My setup is a 7.1 setup, with two speakers in the front dash, one for center channel and then another for phone. I was thinking of putting the SPR-17C there since they are better with voice. Then have the SPS-600 everywhere else, or should I use the SPR-17C in the front doors?
    I don't know much about speakers so any help would be useful. Thanx in advance.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Jan 2008
    look at it like comparing 2 engines-- one with 80 hp, and one with 100 hp. both would propel the car, and run at similar rpm's, but the larger motor would have a little bit more 'oomph'. same for speakers.
    it is fine to run speakers with a little bit less power-- the power rating is mostly derived from the way that voice coils can get rid of the heat that gets generated-- the better they get rid of the heat, the higher the power rating..
    i am not crazy about mixing speakers-- in a 7.1 setup, it can mess up the imaging a little--though, if you can tolerate it then i would say to use them as the center/phone speakers-- they will probably have the most benefit there.
    Jul 2007
    Miami
    Quote Originally Posted by soundman98 View Post
    I understand.
    Also the benfit of using them as center is that they will not be used much. 7.1 is mainly for movies. So I think I have my center speakers, lol. Now I can buy the rest.
    ---------- Post added at 11:41 PM ---------- Previous post was at 11:30 PM ----------
    Let me ask, can speakers be put side by side, or should they have a certain distance from each other?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Jan 2008
    not really. as long as both are securely bolted down, they shouldn't have any problems.
  1. speakers to match with my iDA-X200?
    By bassisfun17 in forum Car Audio
    Last Post: 09-29-2009, 10:54 AM
  2. Amp and sub to match CDT CL-62s in front?
    By willmeyer in forum Car Audio
    Last Post: 05-19-2009, 03:52 PM
  3. Amplifier and Sub match?
    By larchy in forum Car Audio
    Last Post: 03-24-2007, 11:28 AM
  4. Anyone know if I can paint this to match my car ?
    By Cruznlife1 in forum General Hardware Discussion
    Last Post: 07-14-2006, 08:48 PM
  5. How Does It Match Up??
    By b4437 in forum Newbie
    Last Post: 07-04-2006, 09:56 PM
